Using sensor reading in Array
Hello, I’m new to actionscript and this forum so sorry in advance if my posting doesn’t belong here
I’m using arduino and nada to communicate to a flex sensor. Depending on the output of the flex sensor I want to to play certain movie clips in my flash.
For example: when someone bends flex sensor , out put is put into a formula and reads ( 4 )… how do we use the reading ( 4 ) to play movie clip ( 4 )
heres my code
thanks in advance
nadaComponent.addEventListener(“isReady”, function(evt:Object) {
_nada.arduinosms1.analogin1;
this.addEventListener(“parameterChange”, function(evt:Object) {
if (evt.paramName == “arduinosms1.analogin1”) {
_root.label0.text = _nada.arduinosms1.analogin0; // flex sensor reading in text box
num = Math.round((0.05) * (label0.text)); //convert flex output to amount of movies that will be played
label1.text = num; //amount of movies(figure#) to be played
var figure = [“figure0”, “figure1”, “figure2”, “figure3”, “figure4”, “figure5”];
for( i = 0; i < num; i++) { //here’s where im having trouble
figure*.gotoAndPlay(2);*
