So sorry for the hassle. I did say that I was not real familiar with the parseFloat() function. I never use that sort of function as I like to use the methods from Robin2's serial input basics to read serial.
I did a search for how to use parseFloat() and found that you need to use:
while (Serial.available() == 0);
to wait for input and also to extend the serial timeout to give more time for input:
Serial.setTimeout(10000);
I also clear the serial input buffer in between entering the 2 values. Not sure that it is necessary, though.
With those changes it seems to work.
#include <DFRobot_TFmini.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(8, 7);
DFRobot_TFmini TFmini;
uint16_t strength;
int j, k = 0;
int n;
float x, y, z;
float R, r, ang, w, tot_ang, und_ang;
// sampled along radius = R
Serial.setTimeout(10000); // timeout = 10 sec.
Serial.println("Data required");
Serial.print("R = ");
float R = Serial.parseFloat(); Serial.println(R);
// clear receive buffer
while (Serial.available() > 0)
Serial.read();
Serial.print("w = ");
float w = Serial.parseFloat();
Serial.println(w);
Serial.print("Sensor moving along the radius of ");
Serial.println(R);
Serial.print("Sensor moving on the wheel radius of ");
Serial.println(w);
tot_ang = (2 * PI * R) / w;
und_ang = 2;
n = tot_ang / und_ang;
TFmini.begin(mySerial);
