Using Serial Monitor to control 2 servos
This is the code that I have to control a servo, but if I had a second servo, I don’t understand how to add it into the program and how I would write it in the serial monitor. The first set of code is where I have one servo that works from 0-90 degrees and the second set was my attempt of adding in a second servo but I got stuck and now I am here.
Code 1:
#include <Servo.h>
const unsigned int MOTORX_PIN = 9;
const unsigned int MOTOR_DELAY = 15;
const unsigned int SERIAL_DELAY = 5;
const unsigned int BAUD_RATE = 9600;
Servo servo_x;
    Serial.begin(BAUD_RATE);
    servo_x.attach(MOTORX_PIN);
    delay(MOTOR_DELAY);
    servo_x.write(1);
    delay(MOTOR_DELAY);
void loop(){
  const int MAX_ANGLE = 3;
  char degrees[MAX_ANGLE + 1];
  if(Serial.available()){
    int i = 0;
    while(Serial.available() && i < MAX_ANGLE) {
      const char c = Serial.read();
      if (c != -1 && c != '\n')
        degrees[i++] = c;
        delay(SERIAL_DELAY);
    degrees[i] = 0;
    Serial.print(degrees);
    Serial.println(" degrees. ");
    servo_x.write(atoi(degrees));
    delay(MOTOR_DELAY);
Code 2:
#include <Servo.h>
const unsigned int MOTORX_PIN = 6;
const unsigned int MOTORY_PIN = 7;
String readString, servo_1, servo_2;
Servo servo_x;
Servo servo_y;
    servo_y.attach(MOTORY_PIN);
    delay(MOTOR_DELAY);
    servo_x.write(1);
    servo_y.write(2);
    delay(MOTOR_DELAY);
void loop(){
    int i = 0;
        degrees[i++] = c;
    degrees[i] = 0;
    servo_y.write(atoi(degrees));
    delay(MOTOR_DELAY);
Similar topic here
