Using Serial.read() w/ Character Array
I am trying to store constantly updated variables into a character array and I am not getting the consistency that I need.
Here is the code:
char str[4];
if(Serial.available())
      for(int i=0;i<3;i++)
              str[i] = Serial.read();
Is this the best way to read in the variables that I need? I am reading multiple variables at a time which could be two to three digits in length each and are sent next to each other as a whole number. Any help would be greatly appreciated. Thanks.
Try the almost identical:
char str[4] = {'\0'};
if (Serial.available()>=3){
  for (byte i=0; i<3; i++){
:slight_smile:
Since Serial.available() returns an int indicating the number of bytes available, I think your original test
will only be true when there are an odd number of bytes waiting to be read.
if will evaluate anything other than zero ( 0, NULL, '\0', false ) as true.
Be it 2, -3, &variable [if adress != 0] or 'a' :)
Thanks for the code. At first everything works great but upon drastic change in variables, the character arrays start reading random parts of the variables.
Here is the code I am using:
if(Serial.available()>=8)
   char cogX[4] = {'\0'};
char cogY[4] = {'\0'};
char cog_box[4] = {'\0'};
   for(byte i=0;i<3;i++)
     cogX[i] = Serial.read();
   for(byte j=0;j<2;j++)
     cog_box[j] = Serial.read();
   for(byte k=0;k<3;k++)
     cogY[k] = Serial.read();
The main problem is that the first array starts reading the last digit of the previous line of variables and then continues on with the present line.
