Hello,
My first post on this forum, I hope to make it well..
I'm building a metal geared servo based 6DOF arm, that allows the operator to manually manipulate the arm angles and positions, the "record" key positions, and later "play" the positions as a sequence.
Arm and servos work well, controlled by the R3 Arduino. The servos are non-branded, no datasheet or any other info - they have metal gears, and no feedback line - so I hacked one to output a feedback (images attached), it works great when servo is powered, and after detaching PWM signal, I can move the servo gear and "record" the angle.
However, I prefer to have the servo to be POWERED OFF when manipulating it - it is much easier to move the gears, of course, and I believe will do less harm on the long run.
Can anyone suggest the best way to connect the feedback line in this scenario?
I've tried to define the Input as PULLUP, so when the servo GND is attached to the board, I can get a read - but it is in low resolution, and of course when moving the motor, it generates voltage that interfere the reading (is a diode required?).
Thank in advance
