I'm trying to make a library to control an arm with 5 servos. I would like to use the Servo library inside mine so that I can just call the Servo.write(angle) wherever I need it.
Everything compiles fine with the test code below, but the signal sent to the servos is incorrect. No matter what angle I send it always goes beyond 0 degrees. In other words, it's sending an unreasonably small pulse width.
The only thing I can guess is there is some issue with having the Servo instance in the scope of the class, vs having it as a global as is usually used.
Thanks for the help!
header file
#ifndef Arm_h
#define Arm_h
#include "Servo.h"
class Arm
public:
Arm();
void open();
void close();
private:
Servo servo;
#endif
cpp file
#include <WProgram.h>
#include "Arm.h"
#define SERVO_PIN 9
#define MIN_PW 900
#define MAX_PW 2100
#define CLOSE_ANG 90
#define OPEN_ANG 0
#define DELAY 1000
Arm::Arm()
this->servo.attach(SERVO_PIN, MIN_PW, MAX_PW);
void Arm::open()
this->servo.write(OPEN_ANG);
delay(DELAY);
void Arm::close()
this->servo.write(CLOSE_ANG);
delay(DELAY);
pde file
#include <Arm.h>
Arm arm;
arm.close();
/me
