Hey everyone,
Next step in my project is to use a servo. Right now my servo is connected and I'm using the Servo.h to send commands to it. If I go with servo1.write(0) and servo1.write(90) it works, but when I try servo1.write(180) it doesn't move. Why is that ?
Here my code:
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
#include <Bridge.h>
#include <Console.h>
#include <Wire.h>
#include <Servo.h>
#include <YunServer.h>
#include <YunClient.h>
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Select which 'port' M1, M2, M3 or M4. In this case, M1
Adafruit_DCMotor *frontWheels = AFMS.getMotor(2);
// You can also make another motor on port M2
Adafruit_DCMotor *rearWheels = AFMS.getMotor(1);
// Declaring the servo that controls the webcam
Servo *servo1;
// The pin that the LED is attached to
const int ledPin = 13;
// We open the socket 5678 to communicate.
YunServer server(5678);
// Attach the LED to pin 13 as output
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH);
// Bridge startup
Bridge.begin();
// Create with the default frequency 1.6KHz
AFMS.begin();
// Front Wheels initialization
frontWheels->setSpeed(150);
frontWheels->run(FORWARD);
frontWheels->run(RELEASE);
// Rear Wheels initialization
rearWheels->setSpeed(150);
rearWheels->run(FORWARD);
rearWheels->run(RELEASE);
// Attach my servo to pin 10
servo1->attach(10);
server.noListenOnLocalhost();
server.begin();
int _speed;
YunClient client = server.accept();
// There is a new client
if (client) {
client.setTimeout(5);
String command = "none";
digitalWrite(ledPin, LOW);
servo1->write(180);
while (!command.equals("stop")) {
if (client.available() > 0) {
command = client.readString();
Serial.println(command);
if (command.length() == 3) {
if (command.substring(1,3).toInt() > 0 && command.substring(1,3).toInt() <= 100) {
_speed = map(command.substring(1,3).toInt(), 0, 100, 0, 255);
_speed = map(command.substring(1,3).toInt(), 0, -100, 0, 255);
else if (command.length() == 4) {
_speed = map(command.substring(1,4).toInt(), 0, 100, 0, 255);
else {
_speed = 50;
if (command.substring(0,1).equals("f") && _speed > 0) {
rearWheels->setSpeed(_speed);
else if (command.substring(0,1).equals("b") && _speed > 0) {
rearWheels->run(BACKWARD);
else if (command.substring(0,1).equals("l") && _speed > 0) {
frontWheels->setSpeed(165);
frontWheels->run(BACKWARD);
else if (command.substring(0,1).equals("r") && _speed > 0) {
else if (command.substring(0,1).equals("s")) {
else if (command.substring(0,1).equals("0")) {
Serial.println("SERRRVOOOO");
for (int i = 0; i < 255; i++) {
servo1->write(map(i, 0, 255, 0, 180));
delay(3);
else if (command.substring(0,2).equals("90")) {
servo1->write(90);
else if (command.substring(0,3).equals("180")) {
servo1->write(180);
client.stop();
I confirmed that it does go in the else if (180)
Another thing is that I tried using the SoftwareServo librairy but it just doesn't compile on the Yun is there any reason why?
Thank you all
