Using setTimeout()
Hello, I am trying to get my code to run every half second using the setTimeout() command. I keep getting the error 'setTimeout was not declared in this scope. I am confused as to what to do. I just want to use it as a timer and not a variable of any sort.
 #include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 3
#define bus2 4
OneWire ourWire(ONE_WIRE_BUS);
OneWire ourWire2(bus2);
DallasTemperature sensors(&ourWire);
DallasTemperature sensors2(&ourWire2);
 volatile byte rpmcount;
 unsigned int rpm;
 unsigned long timeold;
   attachInterrupt(0, rpm_fun, RISING);
   rpmcount = 0;
   rpm = 0;
   timeold = 0;
void loop(){}
void Results(){
   //if ((timeold % 500) == 0)
     sensors.requestTemperatures();
     Serial.print(sensors.getTempCByIndex(0));
     Serial.print("  ");
     sensors2.requestTemperatures();
     Serial.print(sensors2.getTempCByIndex(0));
     Serial.print(",         ");
     rpm = 30*1000/(millis() - timeold)*rpmcount;
     timeold = millis();
     rpmcount = 0;
     Serial.print(rpm);
     Serial.print(",  ");
     Serial.println(timeold);
     setTimeout("Results()", 500);
 void rpm_fun()
   rpmcount++;
   //Each rotation, this interrupt function is run twice
Thank you!
What gave you the impression that there existed a setTimeout() "command" that would run something every half second?
Is this what you are referring to?
I thought that setTImeout would run in intervals of whatever the parameters were set to. How would you go about this to have the loop iterate every half second?
michael_davidson:
BlinkWithoutDelay example.
Ok, I changed it. But its not running continuously. It outputs one line and doesn't show anything else. Any suggestions?
#define bus2 4
 unsigned int rpm;
 long interval = 500;
   rpmcount = 0;
   rpm = 0;
   timeold = 0;
     unsigned long currentTime = millis();
     if(currentTime - timeold > interval) {
       Serial.print("  ");
       Serial.print(",         ");
       rpm = 30*1000/(currentTime - timeold)*rpmcount;
       timeold = millis();
       rpmcount = 0;
       Serial.print(rpm);
       Serial.print(",  ");
 void rpm_fun()
   rpmcount++;
Nevermind, I figured it out. Thank you!!!!! XD
