I have a program that counts rotations using accelerometer data and I'm trying to display those rotations on a 4digit-7segment display. My problem is that the SevSeg function sevseg.setNumber(displayValue, 1); gives me this error when I try to input a double. "call of overloaded 'setNumber(double&, int)' is ambiguous". The double displayValue is the amount of rotations added to the half rotations and the second parameter is where the decimal place goes. I could just use integers which I know work but it's important that the display also shows half turns.
Here is my code.
#include <Wire.h>
#include "SevSeg.h"
SevSeg sevseg; //Initiate a seven segment controller object
//Variables
int ADXL345 = 0x53;
float X_out, Y_out, Z_out, roll, pitch;
int fullR;
double halfR;
double displayValue = fullR + halfR;
int buttonState = 0;
boolean halfCounted = false;
const int buttonPin = A0;
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
//SevSeg Setup
byte numDigits = 4;
byte digitPins[] = {7, 2, 4, 9};
byte segmentPins[] = {13, 3, 8, 10, 11, 12, 5, 6 };
bool resistorsOnSegments = true;
bool updateWithDelaysIn = true;
byte hardwareConfig = COMMON_CATHODE;
sevseg.begin(hardwareConfig, numDigits, digitPins, segmentPins, resistorsOnSegments);
sevseg.setBrightness(90);
//So I can see my data on the serial port
Wire.begin();
Wire.beginTransmission(ADXL345);
Wire.write(0x2D);
Wire.write(8);
Wire.endTransmission();
delay(10);
//Off-set Calibration
//X-axis
Wire.write(0x1E);
Wire.write(-6);
delay(10);
//Y-axis
Wire.write(0x1F);
Wire.write(-3);
delay(10);
//Z-axis
Wire.write(0x20);
Wire.write(2);
delay(10);
//Accelerometer math to convert it into degrees
Wire.write(0x32);
Wire.endTransmission(false);
Wire.requestFrom(ADXL345, 6, true);
X_out = ( Wire.read() | Wire.read() << 8);
X_out = X_out / 256;
Y_out = ( Wire.read() | Wire.read() << 8);
Y_out = Y_out / 256;
Z_out = ( Wire.read() | Wire.read() << 8);
Z_out = Z_out / 256;
roll = atan(Y_out / sqrt(pow(X_out, 2) + pow(Z_out, 2))) * 180 / PI;
pitch = atan(-1 * X_out / sqrt(pow(Y_out, 2) + pow(Z_out, 2))) * 180 / PI;
//Counting rotations
//Counts spins going clockwise
while (pitch <= -60 && halfCounted == false)
halfR += .5;
halfCounted = true;
while (pitch >= 60 && halfCounted == true)
halfR += .5;
fullR += 1;
//Sends value to the display
sevseg.setNumber(displayValue,1);
sevseg.refreshDisplay();
//Reset code (resets the display using a physical button)
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH)
halfR = 0;
fullR = 0;
sevseg.blank();
//Code to print all data to the serial port
Serial.print("Y-Axis: ");
Serial.print(roll);
Serial.print(" / ");
Serial.print("X-Axis: ");
Serial.print(pitch);
Serial.print("Half_Count: ");
Serial.print(halfR);
Serial.print("Full_Count: ");
Serial.print(fullR);
Serial.println(" / ");
