I am relatively new to Arduino and trying to use some simple wheel encoders to develop a sketch that will correct wheel power values based on the encoder values. I have created a sketch shown here to try to accomplish this task. The results are quite inconsistent and I am thinking I may have some logical errors in my code.
Any suggestions are greatly appreciated.
/* Created by Steve Cline on 17 December 2017
* This sketch is designed to be used with the DFRobot Baron 4WD robot.
* Attached additional equipment includes:
* Arduino UNO R3
* AdaFruit MotorShield V2.3
* Battery pack with 8 AA NiMH cells attached to the motor shield
* Battary pack with 5 AA NiMH cells attached to the microcontroller
* 4 DC 130 motors
* 2 non-contact wheel encoders with 20 PPR resolution attached to back wheels
* Modify the value for the variable "drive" to modify behavior.
#include <Adafruit_MotorShield.h>
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Select which 'port' M1, M2, M3 or M4
Adafruit_DCMotor *LF = AFMS.getMotor(1);
Adafruit_DCMotor *LR = AFMS.getMotor(2);
Adafruit_DCMotor *RR = AFMS.getMotor(3);
Adafruit_DCMotor *RF = AFMS.getMotor(4);
// SET UP VARIABLES
// encoder pins
const int LEncoder = 2;
const int REncoder = 3;
// general variables for settings on the robot
int drive = 120;
// variables to store encoder values
int LCount = 0;
int RCount = 0;
int currentLeft = 0;
int currentRight = 0;
int pastLeft = 0;
int pastRight = 0;
int masterPower = 90;
int slavePower = 90;
int error = 0;
int kp = 5;
AFMS.begin(); // create with the default frequency 1.6KHz
LF->setSpeed(masterPower);
LR->setSpeed(masterPower);
RR->setSpeed(slavePower);
RF->setSpeed(slavePower);
LF->run(RELEASE);
LR->run(RELEASE);
RR->run(RELEASE);
RF->run(RELEASE);
delay(5000); //Wait 5 seconds to set the robot on the course
// drive forward
LF->run(FORWARD);
LR->run(FORWARD);
RR->run(FORWARD);
RF->run(FORWARD);
// drive forward until the encoder returns the preset value on both rear wheels
while (LCount <= drive && RCount <= drive){
currentLeft = digitalRead(LEncoder); // read the left encoder
currentRight = digitalRead(REncoder); // read the right encoder
// test the state of the encoders
if (pastLeft == 0 && currentLeft == 1){
pastLeft = 1;
LCount += 1;
else if (pastLeft == 1 && currentLeft == 0){
pastLeft = 0;
else if (pastRight == 0 && currentRight == 1){
pastRight = 1;
RCount += 1;
else if (pastRight == 1 && currentRight == 0){
pastRight = 0;
error = LCount - RCount;
slavePower += error / kp;
// stop and wait
LF->run(RELEASE);
LR->run(RELEASE);
RR->run(RELEASE);
RF->run(RELEASE);
