Using Softmodem with ATTiny85
hi guys:
I am using the ATTiny85 as microcontroller to send data to iPhone through phone Jack. The test was totally fine when I use regular Arduino. I ran the example code but it has some problem when I am trying to compile it. The following message is the error message.
In file included from SoftModemTiny.ino:1:0:
/Users/MikeLo/Documents/Arduino/libraries/SoftModemATTiny85/SoftModemTiny.h:74:15: error: conflicting return type specified for 'virtual void SoftModemTiny::write(uint8_t)'
virtual void write(uint8_t data);
In file included from /Users/MikeLo/Library/Arduino15/packages/arduino/hardware/avr/1.6.8/cores/arduino/Stream.h:26:0,
from /Users/MikeLo/Documents/Arduino/libraries/SoftModemATTiny85/SoftModemTiny.h:4,
/Users/MikeLo/Library/Arduino15/packages/arduino/hardware/avr/1.6.8/cores/arduino/Print.h:48:20: error: overriding 'virtual size_t Print::write(uint8_t)'
virtual size_t write(uint8_t) = 0;
Error compiling.
The Softmodem for ATTiny has not been update for 4 years. I think I need to fix something in the library. Does anyone have experience with it?
The following is the example code.
#include <SoftModemTiny.h>
#include <ctype.h>
SoftModemTiny modem;
modem.begin();
modem.write(0xff);
modem.write(0x11);
The message does everything you need except actually edit the file. What problem are you having making the needed change?
The message is telling you that the library provides a method called write() that returns nothing (void) but that the method should have a return type of size_t and should return the number of bytes actually written.
hi guys:
I am working on a project that associate with Softmodem which is using ATtiny85 to connect to iPhone Jack . It was working well when I am using Arduino Mega or UNO. However, when I switch to ATTiny85 and using SoftModemTiny library the Arduino IDE compiler give me the error message as follow.
Error compiling.
I wonder if anyone has this time kind of issue before.
Do not cross-post. Threads merged.
