Using SoftPWM and IRremote libraries on Mega 2560 V2
So i managed to change my projects pinout so that neither timers 2 or 3 are used for ouput and I have assigned 2 to the IR library and 3 to the SoftPWM library. The problem occurs when the duty cycle of the SoftPWM output pins are above 2% and what happens is that the IR remote is no longer being decoded, i suspect this is because timer 3 is flashing faster than the timer 2 IR decode transmitter.
My question is, is there a way to modify the SoftPWM library so that when an IR code is being decoded, to pause itself? I could possible attach the IR signal pin to an interrupt and do it that way (is this possible?) but I wanted to see if anyone here has any good suggestions.
Anyone?
Having the same problem. I want to use 6 PWM-Pins for LED control and want IR remote-input on top.
IR with PWM on all pins simply hangs and SoftPWM+IRremote won’t compile :frowning:
Most likely, the softPWM is using up all of the available MCU cycles. The best way to solve this is to use the available hardware PWM on Timers 3,4 & 5. It looks like there are 3 PWM pins for each of these timers = 9 in all. Plus Timer1 seems to have an additional 2 PWM pins available.
Worth investing the time to learn how to set up hardware PWM....usually less than than 5 'C' instructions. There may also be libraries available.
