I have spent some time searching for a code example that could fit my next project, but found nothing that I managed to adapt to my wishlist:
Preferably ATTiny85 based (small, cheap, low power).
Sleep mode to save power when no action is needed.
Wake up when any of two pins are changed :
Rx pin on SoftwareSerial input
A RCWL-0516 "radar" doppler sensor
I found some examples where a watchdog timer was used as interrupt (not what I need), plus this project that I successfully tested to do sleep / wake up procedures with two different input pins, but it seemed to be incompatible with SoftwareSerial. Error message :
Arduino: 1.8.2 (Windows 10), Board: "ATtiny25/45/85, ATtiny85, Internal 1 MHz"
libraries\SoftwareSerial\SoftwareSerial.cpp.o (symbol from plugin): In function `SoftwareSerial::read()':
(.text+0x0): multiple definition of `__vector_2'
sketch\test_attiny85_sleep.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board ATtiny25/45/85.
option enabled in File -> Preferences.
I would appreciate if anyone can advice on existing code examples, or how to modify a watchdog timer based code to monitor two input pins. Maybe this or this could be modified (if compatible with SoftwareSerial).
The project will be a few slave units as stated above, controlled by a master unit that also will accept alarms from the slaves. This is working just fine in my current setup, I just want to add sleep mode to save power in the slave units.
I think I am close now... I managed to wake up and receive data via SoftwareSerial :
#include <SoftwareSerial.h>
#include <avr/sleep.h>
#include <avr/power.h>
unsigned long rx_millis;
unsigned long led_millis;
// ATTINY85 physical pin #
// RESET 1
#define RCWL_pin 3 // InPin from doppler radar module 2
#define LED_pin 4 // led 3
// GND 4
#define BZR_pin 0 // audio buzzer (active) 5
SoftwareSerial mySerial(2, 1); // HC-12 radio (RX, TX) 7,6
// VCC 8
mySerial.begin(2400);
pinMode(RCWL_pin, INPUT);
pinMode(LED_pin, OUTPUT);
pinMode(BZR_pin, OUTPUT);
rx_millis = millis();
led_millis = millis();
attachInterrupt (3, wakeup, CHANGE); // attach interrupt handler
void wakeup() {
sleep_disable ();
power_all_enable ();
if (millis() > led_millis + 500) { // blink = awake indicator
digitalWrite(LED_pin, !digitalRead(LED_pin));
/* By manually transmitting a series of 4 bytes of data from another Arduino, I can
* prevent this ATTiny from sleeping. I can also hear the 4 beeps.
* If I let it goto sleep, it awakes when I make the next transmission - with 4 new beeps.
while (mySerial.available()) { // first recieved byte => wake up works ok
uint8_t j = mySerial.read();
digitalWrite(BZR_pin, 1); // one beep for each byte recieved
delay(5);
digitalWrite(BZR_pin, 0);
delay(200);
if (millis() > rx_millis + 10000) { // turn off the light & sleep after 10 seconds inactivity
digitalWrite(LED_pin, 0);
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
sleep_cpu();
To start with, the led keeps blinking to indicate awake state.
I can keep things like that by feeding mySerial with data from another Arduno (using series of 4 bytes).
When doing that, I can hear one beep for each byte recieved.
If I stop feeding it, it falls asleep (led stops blinking).
When I continue sending data, I hear the 4 beeps and the led starts blinking.
I have no idea how this can work, because I have not specified pin 2 as interrupt source.
But I need pin 3 also to do the same wakeup, and tried to add it in the code above but pin 3 does not wakeup.
