Using solar panel to power small DC Motor 6/9v
I am trying to use a small solar panel to charge a battery and power a small DC motor 6/9v.
I don't know what type of solar panel I need to buy in order to power a motor that is rated for 6V DC, has an operating voltage of 1.5-6.5V DC, and no load current of 280mA. It is a very small standard DC hobbyist motor.
Is it correct to say that the motor is using (280*10^-3)(6.5v) = .5096 Watts? Therefore, I need a solar panel that can produce at lease .5 Watts and 6V?
Also, what type of battery do I need to hold the charge generated by the solar panel? Is a 9V rechargeable battery sufficient?
Thanks,
Dan
6.5V * .28= 1.82 Watts, and if you are charging a battery while doing the motor, you need at least a 2 watts solar panel. Depends on what the battery you need for. If it's just for powering the motor, It's better to get super-capacitor than battery.
dweiss42:
Thanks,
Dan
Whats the motor going to be powering?
For how much of the day will the motor be running?
Do you want the motor to run in the middle of winter?
All these factors are needed to size the solar panel.
How much capacity do you want in the battery?
What battery chemistry?
You realise for most batteries you have to protect against over-charge and over-discharge? (otherwise you
ruin the battery)
If you say what you want to achieve, we can probably advise better.
Sorry for the lack of detail.
A 4 inch diameter pinwheel.
All day and night. I don't want it to turn off.
Assume it is moderately sunny outside.
I'm not sure. How much would you suggest?
I have no preference.
ruin the battery)
I was going to use a rechargeable battery to address this issue. Will this not be sufficient to deal with this problem?
