I have connected the TX and RX Pin of my Arduino Mega 2560 to my RX and TX pin in my SPC Neo DC Motor 2.4A. The Arduino Rx Pin is connected to SPC Neo Tx Pin, and the arduino Tx pin to the SPC Neo Rx Pin.
The problem is, I don't really understand the inner working of how arduino communicate with the h-bridge using the Rx Tx port. It seems like the program I've written is not communicated properly with the DC Motor, so I'm unable to progress forward with the project.
any explanation will be helpful. thank you.
#include <Wire.h>
#define encoder1B 4
#define encoder2B 5
volatile unsigned int encoderpulse= 0;
double errorM1;
Wire.begin();
attachInterrupt (0, Encoder1, RISING); //if there is rising on pin 2, then process will be interrupt. Move
//to function Encoder1
attachInterrupt (1, Encoder2, RISING); //if there is rising on pin 3, then process will be interrupt. Move
//to function Encoder2
Serial.begin(38400);
pinMode(2,INPUT); // Set pin as input for encoder A of motor 1
pinMode(3,INPUT); // Set pin as input for encoder A of motor 2
pinMode(4,INPUT); // Set pin as input for encoder B of motor 1
pinMode(5,INPUT); // Set pin as input for encoder B of motor 2
errorM1 = 40 - encoder2pulse;
while(errorM1 >5 || errorM1<0)
if (errorM1 >= 5)
Serial.write(0x35); //ccw
Serial.write(0x40);
else if(errorM1 <= 0)
Serial.write(0x34); //cw
Serial.write(0x40);
Serial.write(0x33);
void Encoder1()
if(digitalRead(encoder1B) == HIGH) //if encoder B of motor 1 is high
encoderpulse = encoderpulse +1; //counting pulse
if (encoderpulse >=1633) //1644 PPR from 0 to 1633
encoderpulse = 0; //if more than 1633 then reset
else //if encoder B of motor 1 is low
encoderpulse = encoderpulse -1;
if (encoderpulse == 65535) //the encoder will show 65535 after 0 if counting down
encoderpulse=1633;
void Encoder2()
if(digitalRead(encoder2B) == HIGH) //if encoder B of motor 1 is high
encoder2pulse = encoder2pulse +1; //counting pulse
if (encoder2pulse >=1633) //1644 PPR from 0 to 1633
encoder2pulse = 0; //if more than 1633 then reset
else if(digitalRead(encoder2B) == LOW) //if encoder B of motor 1 is low
encoder2pulse = encoder2pulse -1;
if (encoder2pulse == 65535) //the encoder will show 65535 after 0 if counting down
encoder2pulse=1633;
