Hey everyone, I'm trying to use a MEGA 2560 to pull data over SPI from a inertial sensor. Here's the data sheet for the sensor. I've gotten it to a point where it gives me a constant (wrong) number for a reading when stationary but looks correct when actually moving. For example, reading XGYRO, YGYRO, and ZGYRO give the same numbers (something like >500 deg/s) when not moving but if I wiggle the device around I get ~1-5 deg/s. Same thing for the gyro. Supply reading gives me exactly 4V every time (should be 5). As an added bonus, the error bit is always high but the data sheet doesn't really say much about it. Can someone help me out here?
SPI.begin(); // begin SPI comms
pinMode(IRQ_PIN, INPUT); // initialize Interrupt Request pin
pinMode (SLAVE_PIN, OUTPUT); // init slave select pin
SPI.setDataMode(SPI_MODE3); // set data mode
SPI.setBitOrder(MSBFIRST); // set most significant bit first
SPI.setClockDivider(SPI_CLOCK_DIV8); // set timing mode
digitalWrite(SLAVE_PIN, HIGH); // default slave select is HIGH
delay(100); // wait for module to start up
int input=Serial.read();
float result = readRegister( XGYRO_OUT, 14, F_GYRO_READ );
Serial.println( result, DEC );
delay(200);
// reads data from specified address and returns a scaled value
float readRegister( byte address, int releventBits, double scale )
Serial.print( "Reading Register:\t" ); //
address &= 0b01111111; // make sure MSB bit = 0 (to specify R/W as R only)
Serial.println( address, HEX );
digitalWrite( SLAVE_PIN, LOW ); // start comm process
SPI.transfer( address ); // first byte is the address
SPI.transfer( 0x00 ); // second byte doesn't matter
digitalWrite( SLAVE_PIN, HIGH );
delay(10);
long unsigned int result = SPI.transfer(0x00); // transmit 0 to retrieve requested data
if( (result >> 6) & 1 == 1 ) { Serial.println("ERROR"); }
result = result << 8;
result = result | SPI.transfer(0x00); // shift over first byte and add on new byte
Serial.print("Combined bytes:\t");
Serial.println( result, BIN );
result &= (unsigned int)(pow(2, releventBits) - 1); // cut off the bits that are unrequested
Serial.print("Final result:\t");
digitalWrite( SLAVE_PIN, HIGH ); // reset slave to off
return result * scale; // multiply by scale to get final result
