Hi All
I was hoping someone might be able to shed some light for me with using an Arduino Due with Maxim MAX1257 chip (http://www.maximintegrated.com/en/products/analog/data-converters/analog-to-digital-converters/MAX1257.html). It is quite a capable device but I am not having much luck interfacing to it.
Looking at the timing on an oscilloscope it looks to me as though the timing and bit sequence is correct however I can’t seem to enable and set the registers for the DAC.
If any one has any familiarity with the device (or family of devices) and knows off hand what the issue is I would be most appreciative. Probably missing setting a register or the like
MAX1257 Control
This will attempt to control MAX1257 via SPI
// include the SPI library:
#include <SPI.h>
const int slaveSelectPin = 52;
Serial.println("Set up SPI");
// set the slaveSelectPin as an output:
pinMode (slaveSelectPin, OUTPUT);
// initialize SPI:
SPI.begin(slaveSelectPin);
SPI.setDataMode(slaveSelectPin, SPI_MODE2);
SPI.setBitOrder(slaveSelectPin, MSBFIRST);
SPI.setClockDivider(slaveSelectPin, 21);
Serial.println("SPI Setup Complete\n");
//Send setup bits to MAX1257
//DAC Select (Table 1)
//Turn on DACs (Table 21)
SPI.transfer(slaveSelectPin,0b00010000,SPI_CONTINUE); //DAC Select
SPI.transfer(slaveSelectPin,0b1111111,SPI_CONTINUE); //Turn on DAC 7-4
SPI.transfer(slaveSelectPin,0b11110011); //Turn on DAC 3-0
delay(2); //Delay 2ms
//Send DAC Select (Table 1)
//Send data to DAC (Table 20)
SPI.transfer(slaveSelectPin,0b10101000,SPI_CONTINUE); //Load input registers and DA outputs (Should set halfway to 0b1000000)
SPI.transfer(slaveSelectPin,0b00000000);
raydiator:
Hi All
Looking at the timing on an oscilloscope it looks to me as though the timing and bit sequence is correct however I can't seem to enable and set the registers for the DAC.
// Try this in your setup()
SPI.transfer(slaveSelectpin,0B00010000,SPI_CONTINUE); // DAC Select
SPI.transfer(slaveSelectpin,0B00010000,SPI_CONTINUE); // Set all registers to 0; {table 20}
SPI.transfer(slaveSelectpin,0B00000000); // Set all registers to 0;
SPI.transfer(slaveSelectpin,0B11101111,SPI_CONTINUE); // Transfer Registers values {table 20}
SPI.transfer(slaveSelectpin,0B11110000); // to all DAC's (1 for 1)
SPI.transfer(slaveSelectpin,0B11111111,SPI_CONTINUE); // Power up all DAC's ,{table 21}
SPI.transfer(slaveSelectpin,0B11110010); //
Delay(1000);
SPI.transfer(slaveSelectpin,0B00011000,SPI_CONTINUE); // Set all registers to 0xFFF; table 20
SPI.transfer(slaveSelectpin,0B11101111,SPI_CONTINUE); // Transfer Register value to DAC,table 20
Chuck.
Thanks Chuck.
Getting close. The ports now change state but they aren't jumping from 0x00 to 0xFF. Both jump to a single state and it occurs slightly after the last CLK signal.
I will keep trying as now it appears the part is alive but have to just give it the right instructions
Edit: DAC power up and DAC power down seem to work. Setting DAC values seems to be the issue.
Hi Chuck
Figured it out. The setup register
Thanks again
