I have made an attempt at applying SPID example myself. It is set inside void loop(), sending a myservo.write(output);
I'm doing Serial.print() to get values of output, input and Bearing
I'm getting a value of 255 for output and gap matches Bearing (which is determined by two sets of Lat, lng values.
gap should be difference between input and setpoint but it isn't getting the setpoint I think.
output value doesn't change even if I change input value.
#include <PID_v2.h>
#include "heltec.h"
#include "Simpletimer.h"
#include <Adafruit_BMP280.h>
#include <Arduino.h>
#include <Adafruit_BNO08x.h>
#include "BluetoothSerial.h"
#include <ESP32Servo.h>
#include <TinyGPSPlus.h>
// Define the aggressive and conservative Tuning Parameters
double aggKp = 4, aggKi = 0.2, aggKd = 1;
double consKp = 1, consKi = 0.05, consKd = 0.25;
// Specify the links and initial tuning parameters
PID_v2 myPID(consKp, consKi, consKd, PID::Direct);
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
#if !defined(CONFIG_BT_SPP_ENABLED)
#error Serial Bluetooth not available or not enabled. It is only available for the ESP32 chip.
#endif
#ifdef FAST_MODE
// Top frequency is reported to be 1000Hz (but freq is somewhat variable)
sh2_SensorId_t reportType = SH2_GYRO_INTEGRATED_RV;
long reportIntervalUs = 2000;
#else
// Top frequency is about 250Hz but this report is more accurate
sh2_SensorId_t reportType = SH2_ARVR_STABILIZED_RV;
long reportIntervalUs = 5000;
#endif
String rssi = "RSSI --";
String packSize = "--";
String packet;
Adafruit_BMP280 bmp;
TinyGPSPlus gps;
unsigned long last = 0UL;
Servo myservo;
int pos = 0; // variable to store the servo position
int servoPin = 12;
BluetoothSerial SerialBT;
boolean confirmRequestPending = true;
char Incoming_value = 0;
struct euler_t {
float yaw;
float pitch;
float roll;
} ypr;
#define BNO08X_RESET -1
#define BNO08X_CS 10
#define BNO08X_INT 9
#define BMP_SCK (13)
#define BMP_MISO (12)
#define BMP_MOSI (11)
#define BMP_CS (10)
#define BAND 915E6
Simpletimer timer1;
Simpletimer timer2;
Simpletimer timer3;
Simpletimer timer4;
Simpletimer timer5;
Simpletimer timer6;
Adafruit_BNO08x bno08x(BNO08X_RESET);
sh2_SensorValue_t sensorValue;
void loRaPackageSend() {
int packetSize = LoRa.parsePacket();
if (packetSize) { cbk(packetSize); }
void GPSDataLoad() {
GPSloop();
callToGPSLAT();
callToGPSLONG();
callToGPSALT();
callToGPSAGE();
callToGPSSPEED();
void BMP280Load() {
BMPloop();
void BNO085Load() {
BNOloop();
void DistanceWithAltitude() {
distanceWithAltitude();
void PtoP_bearing() {
PtoP_Bearing();
vehicleBearingAdjustment();
double brng = PtoP_Bearing();
Heltec.begin(true /*DisplayEnable Enable*/, true /*Heltec.Heltec.Heltec.LoRa Disable*/, true /*Serial Enable*/, true /*PABOOST Enable*/, BAND /*long BAND*/);
BTsetup();
GPSsetup();
BMPsetup();
BNOsetup();
Heltec.display->init();
Heltec.display->flipScreenVertically();
Heltec.display->setFont(ArialMT_Plain_10);
timer1.register_callback(loRaPackageSend);
timer2.register_callback(GPSDataLoad);
timer3.register_callback(BMP280Load);
timer4.register_callback(BNO085Load);
timer5.register_callback(DistanceWithAltitude);
timer6.register_callback(PtoP_bearing);
Heltec.display->clear();
Heltec.display->drawString(0, 0, "Heltec.LoRa Initial success!");
Heltec.display->drawString(0, 10, "Wait for incoming data...");
Heltec.display->display();
LoRa.receive();
myPID.Start(brng, // input
0, // current output
ypr.yaw); // setpoint
BTloop();
timer1.run(100);
timer2.run(250);
timer3.run(500);
timer4.run(100);
timer5.run(500);
timer6.run(100);
steerloop();
phoneInput();
int Bearing = ((((int)brng) + 540) % 360) - 180;
const double input = Bearing;
double gap = abs(myPID.GetSetpoint() - input); // distance away from setpoint
if (gap < 10) {
// we're close to setpoint, use conservative tuning parameters
myPID.SetTunings(consKp, consKi, consKd);
// we're far from setpoint, use aggressive tuning parameters
myPID.SetTunings(aggKp, aggKi, aggKd);
const double output = myPID.Run(input);
Serial.print("output");
Serial.print(output);
Serial.print("brng");
Serial.print(Bearing);
Serial.print("ypr.yaw");
Serial.print(ypr.yaw);
Serial.print("gap");
Serial.print(gap);
void BMPsetup() {
Serial.println(F("BMP280 Forced Mode Test."));
if (!bmp.begin()) {
Serial.println(F("Could not find a valid BMP280 sensor, check wiring or "
"try a different address!"));
while (1) delay(10);
bmp.setSampling(Adafruit_BMP280::MODE_FORCED, /* Operating Mode. */
Adafruit_BMP280::SAMPLING_X2, /* Temp. oversampling */
Adafruit_BMP280::SAMPLING_X16, /* Pressure oversampling */
Adafruit_BMP280::FILTER_X16, /* Filtering. */
Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
double BMPloop() {
if (bmp.takeForcedMeasurement()) {
Serial.println("Forced measurement failed!");
double Altitude = (bmp.readAltitude(1013.25));
return (Altitude);
void setReports(sh2_SensorId_t reportType, long report_interval) {
Serial.println("Setting desired reports");
if (!bno08x.enableReport(reportType, report_interval)) {
Serial.println("Could not enable stabilized remote vector");
void BNOsetup(void) {
while (!Serial) delay(10);
Serial.println("Adafruit BNO08x test!");
if (!bno08x.begin_I2C()) {
Serial.println("Failed to find BNO08x chip");
while (1) { delay(10); }
Serial.println("BNO08x Found!");
setReports(reportType, reportIntervalUs);
Serial.println("Reading events");
//delay(10);
void quaternionToEuler(float qr, float qi, float qj, float qk, euler_t* ypr, bool degrees = false) {
float sqr = sq(qr);
float sqi = sq(qi);
float sqj = sq(qj);
float sqk = sq(qk);
ypr->yaw = atan2(2 * -1 * (qi * qj + qk * qr), (sqi - sqj - sqk + sqr));
ypr->pitch = asin(-2.0 * (qi * qk - qj * qr) / (sqi + sqj + sqk + sqr));
ypr->roll = atan2(2.0 * (qj * qk + qi * qr), (-sqi - sqj + sqk + sqr));
if (degrees) {
ypr->yaw *= RAD_TO_DEG;
ypr->pitch *= RAD_TO_DEG;
ypr->roll *= RAD_TO_DEG;
void quaternionToEulerRV(sh2_RotationVectorWAcc_t* rotational_vector, euler_t* ypr, bool degrees = false) {
quaternionToEuler(rotational_vector->real, rotational_vector->i, rotational_vector->j, rotational_vector->k, ypr, degrees);
void quaternionToEulerGI(sh2_GyroIntegratedRV_t* rotational_vector, euler_t* ypr, bool degrees = false) {
void BNOloop() {
if (bno08x.wasReset()) {
Serial.print("sensor was reset ");
if (bno08x.getSensorEvent(&sensorValue)) {
switch (sensorValue.sensorId) {
case SH2_ARVR_STABILIZED_RV:
quaternionToEulerRV(&sensorValue.un.arvrStabilizedRV, &ypr, true);
case SH2_GYRO_INTEGRATED_RV:
// faster (more noise?)
quaternionToEulerGI(&sensorValue.un.gyroIntegratedRV, &ypr, true);
static long last = 0;
long now = micros();
last = now;
void BTConfirmRequestCallback(uint32_t numVal) {
Serial.println(numVal);
void BTAuthCompleteCallback(boolean success) {
confirmRequestPending = false;
if (success) {
Serial.println("Pairing success!!");
Serial.println("Pairing failed, rejected by user!!");
void BTsetup() {
SerialBT.enableSSP();
SerialBT.onConfirmRequest(BTConfirmRequestCallback);
SerialBT.onAuthComplete(BTAuthCompleteCallback);
SerialBT.begin("ESP32test"); //Bluetooth device name
Serial.println("The device started, now you can pair it with bluetooth!");
myservo.setPeriodHertz(330);
myservo.attach(servoPin, 700, 2100);
void BTloop() {
if (confirmRequestPending) {
if (Serial.available()) {
int dat = Serial.read();
if (dat == 'Y' || dat == 'y') {
SerialBT.confirmReply(true);
SerialBT.confirmReply(false);
SerialBT.write(Serial.read());
if (SerialBT.available()) {
Serial.write(SerialBT.read());
//delay(20);
void phoneInput() {
if (SerialBT.available() > 0) {
Incoming_value = SerialBT.read();
if (Incoming_value == '0') {
Serial.println("Off");
} else if (Incoming_value == '1') {
Serial.println("On");
} else if (Incoming_value == '2') {
Serial.println("Fwd");
} else if (Incoming_value == '3') {
Serial.println("Aft");
} else if (Incoming_value == '4') {
Serial.println("Left");
myservo.write(135);
} else if (Incoming_value == '5') {
Serial.println("Right");
myservo.write(45);
} else if (Incoming_value == '6') {
Serial.println("");
void GPSsetup() {
Serial1.begin(9600, SERIAL_8N1, 2, 17);
void GPSloop() {
while (Serial1.available() > 0)
gps.encode(Serial1.read());
if (gps.location.isUpdated()) {
//Serial.print(F("LOCATION Fix Age="));
//Serial.print(gps.location.age());
//Serial.print(F("ms Raw Lat="));
//Serial.print(gps.location.rawLat().negative ? "-" : "+");
//Serial.print(gps.location.rawLat().deg);
//Serial.print("[+");
//Serial.print(gps.location.rawLat().billionths);
//Serial.print(F(" billionths], Raw Long="));
//Serial.print(gps.location.rawLng().negative ? "-" : "+");
//Serial.print(gps.location.rawLng().deg);
//Serial.print(gps.location.rawLng().billionths);
//Serial.print(F(" billionths], Lat="));
//Serial.print(gps.location.lat(), 6);
//Serial.print(F(" Long="));
//Serial.println(gps.location.lng(), 6);
else if (gps.date.isUpdated()) {
//Serial.print(F("DATE Fix Age="));
//Serial.print(gps.date.age());
//Serial.print(F("ms Raw="));
//Serial.print(gps.date.value());
//Serial.print(F(" Year="));
//Serial.print(gps.date.year());
//Serial.print(F(" Month="));
//Serial.print(gps.date.month());
//Serial.print(F(" Day="));
//Serial.println(gps.date.day());
else if (gps.time.isUpdated()) {
//Serial.print(F("TIME Fix Age="));
//Serial.print(gps.time.age());
//Serial.print(gps.time.value());
//Serial.print(F(" Hour="));
//Serial.print(gps.time.hour());
//Serial.print(F(" Minute="));
//Serial.print(gps.time.minute());
//Serial.print(F(" Second="));
//Serial.print(gps.time.second());
//Serial.print(F(" Hundredths="));
//Serial.println(gps.time.centisecond());
else if (gps.speed.isUpdated()) {
//Serial.print(F("SPEED Fix Age="));
//Serial.print(gps.speed.age());
//Serial.print(gps.speed.value());
//Serial.print(F(" Knots="));
//Serial.print(gps.speed.knots());
//Serial.print(F(" MPH="));
//Serial.print(gps.speed.mph());
//Serial.print(F(" m/s="));
//Serial.print(gps.speed.mps());
//Serial.print(F(" km/h="));
//Serial.println(gps.speed.kmph());
else if (gps.course.isUpdated()) {
//Serial.print(F("COURSE Fix Age="));
//Serial.print(gps.course.age());
//Serial.print(gps.course.value());
//Serial.print(F(" Deg="));
//Serial.println(gps.course.deg());
else if (gps.altitude.isUpdated()) {
//Serial.print(F("ALTITUDE Fix Age="));
//Serial.print(gps.altitude.age());
//Serial.print(gps.altitude.value());
//Serial.print(F(" Meters="));
//Serial.print(gps.altitude.meters());
//Serial.print(F(" Miles="));
//Serial.print(gps.altitude.miles());
//Serial.print(F(" KM="));
//Serial.print(gps.altitude.kilometers());
//Serial.print(F(" Feet="));
//Serial.println(gps.altitude.feet());
else if (gps.satellites.isUpdated()) {
//Serial.print(F("SATELLITES Fix Age="));
//Serial.print(gps.satellites.age());
//Serial.print(F("ms Value="));
//Serial.println(gps.satellites.value());
else if (gps.hdop.isUpdated()) {
//Serial.print(F("HDOP Fix Age="));
//Serial.print(gps.hdop.age());
//Serial.print(F("ms raw="));
//Serial.print(gps.hdop.value());
//Serial.print(F(" hdop="));
//Serial.println(gps.hdop.hdop());
else if (millis() - last > 5000) {
if (gps.location.isValid()) {
static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
double distanceToLondon =
TinyGPSPlus::distanceBetween(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON);
double courseToLondon =
TinyGPSPlus::courseTo(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON);
Serial.print(F("LONDON Distance="));
Serial.print(distanceToLondon / 1000, 6);
Serial.print(F(" km Course-to="));
Serial.print(courseToLondon, 6);
Serial.print(F(" degrees ["));
Serial.print(TinyGPSPlus::cardinal(courseToLondon));
Serial.println(F("]"));
Serial.print(F("DIAGS Chars="));
Serial.print(gps.charsProcessed());
Serial.print(F(" Sentences-with-Fix="));
Serial.print(gps.sentencesWithFix());
Serial.print(F(" Failed-checksum="));
Serial.print(gps.failedChecksum());
Serial.print(F(" Passed-checksum="));
Serial.println(gps.passedChecksum());
if (gps.charsProcessed() < 10)
Serial.println(F("WARNING: No GPS data. Check wiring."));
last = millis();
double distanceWithAltitude() {
double NewLat = callToGPSLAT();
double NewLong = callToGPSLONG();
double lat1 = gps.location.lat();
double lon1 = gps.location.lng();
double lat2 = NewLat;
double lon2 = NewLong;
lon1 = lon1 * PI / 180;
lon2 = lon2 * PI / 180;
lat1 = lat1 * PI / 180;
lat2 = lat2 * PI / 180;
// Haversine formula
double dlon = lon2 - lon1;
double dlat = lat2 - lat1;
double a = pow(sin(dlat / 2), 2)
+ cos(lat1) * cos(lat2)
* pow(sin(dlon / 2), 2);
double c = 2 * asin(sqrt(a));
// Radius of earth in kilometers. Use 3956
// for miles
double r = 3956;
double distance = (c * r);
//Serial.print("distance ");
//Serial.println(distance);
double distanceFeet = distance * 5280;
return distanceFeet;
double callToGPSAGE() {
String Long = packet.substring(50, 60);
double AgeNew = Long.toDouble();
return AgeNew;
double callToGPSLONG() {
String Long = packet.substring(19, 38);
double LongNew = Long.toDouble();
return LongNew;
double callToGPSALT() {
String Alt = packet.substring(41, 47);
double AltNew = Alt.toDouble();
return AltNew;
double callToGPSSPEED() {
String Speed = packet.substring(50, 55);
double SpeedNew = Speed.toDouble();
return SpeedNew;
double callToGPSLAT() {
String Lat = packet.substring(3, 19);
double LatNew = Lat.toDouble();
return (LatNew);
double PtoP_Bearing() {
double NewLat = 46.5596814;
double NewLong = -122.2908778;
double lat = 47.9089450;
double lon = -122.2439150;
double teta1 = radians(lat);
double teta2 = radians(lat2);
double delta1 = radians(lat2 - lat);
double delta2 = radians(lon2 - lon);
//==================Heading Formula Calculation================//
double y = sin(delta2) * cos(teta2);
double x = cos(teta1) * sin(teta2) - sin(teta1) * cos(teta2) * cos(delta2);
double brng = atan2(y, x);
brng = degrees(brng); // radians to degrees
brng = (((int)brng + 360) % 360);
return brng;
double vehicleBearingAdjustment() {
int brng = PtoP_Bearing();
double YAW = ypr.yaw;
int DriveHeading = ((((int)YAW - brng) + 540) % 360) - 180; //heading error is in range -180 to 179
Serial.print("DriveHeading");
Serial.print(DriveHeading); //heading error is in range -180 to 179
//Serial.print("brng ");
//Serial.print(brng);
if (DriveHeading > -5 && DriveHeading < 5) Serial.println("NOT TURNING: ");
if (DriveHeading < -5) Serial.println("Turn Right: ");
if (DriveHeading > 5) Serial.println("Turn Left: ");
return DriveHeading;
void cbk(int packetSize) {
packet = "";
packSize = String(packetSize, DEC);
for (int i = 0; i < packetSize; i++) { packet += (char)LoRa.read(); }
rssi = "RSSI " + String(LoRa.packetRssi(), DEC);
//Serial.println(packet);
LoRaData();
void LoRaData() {
double AgeNew = callToGPSAGE();
double YAW = vehicleBearingAdjustment();
double distanceFeet = distanceWithAltitude();
Heltec.display->setTextAlignment(TEXT_ALIGN_LEFT);
String a = String(YAW);
String b = String((ypr.yaw), 2);
String c = String(brng, 2);
String d = String(distanceFeet, 1);
Heltec.display->drawString(0, 0, "Turn to GPS heading " + a);
Heltec.display->drawString(0, 10, "GPS Heading " + c);
Heltec.display->drawString(0, 20, "Feet " + d);
if (YAW - brng < 5 && YAW - brng > -5) Heltec.display->drawString(0, 30, "No need to turn");
else if (YAW - brng > 5 && YAW - brng < 180) Heltec.display->drawString(0, 30, "turn left");
else if (YAW - brng < -5 || YAW - brng > 180) Heltec.display->drawString(0, 30, "turn right");
//Serial.print(DriveBearing);
if (gps.location.age() > 1500) {
Heltec.display->drawString(65, 40, "CK RX GPS ");
if (AgeNew > 1500) {
Heltec.display->drawString(0, 45, "Check TX GPS");
void steerloop() {
double DriveBearing = vehicleBearingAdjustment();
if (DriveBearing >= 5) {
myservo.write(135);
if (DriveBearing <= -5) {
myservo.write(45);
} else if (DriveBearing < 5 && DriveBearing > -5) {
myservo.write(95);
