Happy to post full sketch, although it's 1300+ lines, so maybe easier if I explain my problem with snippets?
I have a Mega 2560 sketch that sends and receives messages over MQTT.
There's a callback function which, when MQTT client receives an incoming message, it checks to see what topic the message is on, before assigning e.g. a command, setting, or value to an Arduino variable, e.g. character array.
e.g. when the audio track changes, this callback writes the track name to a char array:
#define trackLength 30 // Now Playing track: max length to accept / display onto Arduino
char track[trackLength+1];
char buff[43]; // general buffer. char array. Assuming topicroot is max 10 chars with null terminator
// this should never ever exceed 43. #sram
void callback(char* topic, byte* payload, unsigned int length) {
payload[length] = '\0';
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, audiovector, titlevector);
if(strcmp(topic, buff) == 0)
for (int i=0; i<trackLength+1; ++i)
track[i] = payload[i];
[...] other settings / values written in this function
A while ago I ran into issues caused by hitting the 8k SRAM limit, but reduced SRAM usage by 60% by simply being more careful with char array sizes, more judicious use of structs, using defines instead of variables where poss (e.g. see above), and also by setting up this re-usable global buffer (char buff[43]).
I started to use this buffer for other things in the sketch, e.g. writing to the display:
for (int i = 0; i < circuitCount; i++) {
sprintf (buff, "%i", lightCircuit[i].level);
u8g.drawStr (circuit_display_x_coord+(circuitSpacing/2) - (u8g.getStrWidth(buff)/2), minor_text_y_coord, buff);
if (i == currentCircuit-1) { // indicate current circuit being controlled
// dot -- u8g.drawStr (circuit_display_x_coord+(circuitSpacing/2) - (u8g.getStrWidth(buff)/2) - 7, minor_text_y_coord-3, ".");
u8g.drawLine(circuit_display_x_coord+(circuitSpacing/2) - (u8g.getStrWidth(buff)/2), minor_text_y_coord+4, circuit_display_x_coord+(circuitSpacing/2) + (u8g.getStrWidth(buff)/2) -2, minor_text_y_coord+4);
// Serial.print("Writing display: circuit value ");
// Serial.print(i);
// Serial.print(" ");
// Serial.println(buff);
circuit_display_x_coord = circuit_display_x_coord + circuitSpacing;
After working fine over many revisions over the last 6 months, after a code revision yesterday the sketch randomly broke. I traced the problem to some more settings I had added into the Sketch.
In my callback function I previously had this, and it worked fine:
// Settings
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, circuitcountvector); // home/bedroom/settings/circuit_count
if(strcmp(topic, buff) == 0) circuitCount = atoi( (const char*) payload );
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, circuit_1_namevector); // home/bedroom/settings/circuit_1_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) lightCircuit[0].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, circuit_2_namevector); // home/bedroom/settings/circuit_2_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) lightCircuit[1].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, circuit_3_namevector); // home/bedroom/settings/circuit_3_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) lightCircuit[2].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, circuit_4_namevector); // home/bedroom/settings/circuit_4_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) lightCircuit[3].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, circuit_5_namevector); // home/bedroom/settings/circuit_5_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) lightCircuit[4].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, circuit_6_namevector); // home/bedroom/settings/circuit_6_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) lightCircuit[5].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, light_scene_1_namevector); // home/bedroom/settings/light_scene_1_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) lightScene[0].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, light_scene_2_namevector); // home/bedroom/settings/light_scene_2_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) lightScene[1].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, light_scene_3_namevector); // home/bedroom/settings/light_scene_3_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) lightScene[2].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, light_scene_4_namevector); // home/bedroom/settings/light_scene_4_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) lightScene[3].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, light_scene_5_namevector); // home/bedroom/settings/light_scene_5_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) lightScene[4].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, audio_fave_1_namevector); // home/bedroom/settings/audio_fave_1_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) audioFave[0].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, audio_fave_2_namevector); // home/bedroom/settings/audio_fave_2_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) audioFave[1].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, audio_fave_3_namevector); // home/bedroom/settings/audio_fave_3_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) audioFave[2].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, audio_fave_4_namevector); // home/bedroom/settings/audio_fave_4_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) audioFave[3].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, audio_fave_5_namevector); // home/bedroom/settings/audio_fave_5_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) audioFave[4].name[i] = payload[i];
To the end of this I added pretty much more of the same:
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, heat_fave_1_namevector); // home/bedroom/settings/heat_fave_1_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) heatingProfile[0].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, heat_fave_2_namevector); // home/bedroom/settings/heat_fave_2_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) heatingProfile[1].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, heat_fave_3_namevector); // home/bedroom/settings/heat_fave_3_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) heatingProfile[2].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, heat_fave_4_namevector); // home/bedroom/settings/heat_fave_4_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) heatingProfile[3].name[i] = payload[i];
sprintf (buff, "%s/%s/%s/%s", rootvector, zonevect, settingsvector, heat_fave_5_namevector); // home/bedroom/settings/heat_fave_5_name
if(strcmp(topic, buff) == 0) for (int i=0; i<nameLength+1; ++i) heatingProfile[4].name[i] = payload[i];
... and it broke the functionality of my sketch. I mean, the sketch still runs, but some other areas of the sketch, e.g. pressing buttons to send MQTT messages, displaying the screen output, and more.
I know you probably need to see the code for the bits of the functionality that have broken, but basically can someone advise me on whether it's a very silly idea to use a global buffer variable in this way, or provide any other ideas?
