Using Step/Dir method to drive a stepper motor
Hi, I am new of the Arduino programming, I had purchased a stepper motor which integrated with the controller. I had writing some code and try to driving the motor rotate faster. But I can not realize my purpose, It cost 15 seconds to run a cycle. It has slightly change when I reduce the delay but the difference in 1-2 seconds different.
The code as following shown.
// Define pin connections & motor's steps per revolution
const int dirPin = 2;
const int stepPin = 3;
const int stepsPerRevolution = 200;
	// Declare pins as Outputs
	pinMode(stepPin, OUTPUT);
	pinMode(dirPin, OUTPUT);
  int x = 0;
	// Set motor direction clockwise
	digitalWrite(dirPin, HIGH);
	// Spin motor slowly
	for(int x = 0; x < 50 * stepsPerRevolution; x++)
    Serial.println(x);
		digitalWrite(stepPin, HIGH);
		delayMicroseconds(500);
    digitalWrite(stepPin, LOW);
Hope anyone who had played with Step/Dir control can give me some suggestion to increase the rotational speed.
Try to remove Serial.print() line too - it take more time for printing than delays itself.
You may have a default microstepping ratio set.
Thank you problem solved
Please mark the thread as "solved"
What did you do to fix the problem?
Tom.... :smiley: :+1: :coffee: :australia:
Hi, Tom. I just delay the Serial.(9600). Do not understand the theory but the code working.
Did you try a higher baud rate, 115200?
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
Hi, Tom.
I did not try high rate because the datasheet of motor show 9600.
Thank you
Okay, fair enough.
What kind of motor are you using that has a baud rate specification?
It's name is PD60-4-1076
