Using Stepper motor with Lidar(Nema17 + Lidar )
Hi, I have a stepper motor Nema 17 with A4988 and Garmin Lidar lite v3
I want to operate both Stepper motor and lidar simultaneously.
According to change lidar sensor length, i want to make stepper motor 'clockwise run, stop, counterclockwise run'
But, It didn't work.. would you mind to tell me any problem with my code?
Garmin LIDAR lite v3
[https://static.garmin.com/pumac/LIDAR_Lite_v3_Operation_Manual_and_Technical_Specifications.pdf]
NEMA17
[https://www.handsontec.com/dataspecs/17HS4401S.pdf]
#include <Wire.h> //
#include <LIDARLite.h>
#include <AccelStepper.h>
LIDARLite lidarlite;
int cnt = 0;
int dist = lidarlite.distance();
const int dirp = 2;
const int stepp = 3;
//State definitions
/*#define RSPD 01
#define RJSTR 02
#define STOPPED 03
//State variable
int state;*/
AccelStepper mystepper(AccelStepper::DRIVER, stepp, dirp);
  lidarlite.begin(0,true); //
  lidarlite.configure(0); //
  mystepper.setMaxSpeed(200);
  mystepper.setSpeed(50); //
  mystepper.moveTo(-800);
  Serial.println(dist);
 /* switch(state){
    case RSPD :
      mystepper.runSpeed();
    case RJSTR:
      mystepper.run();
    case STOPPED:
  if(dist<30){
  else if(dist >= 30 && dist <= 150){
    mystepper.stop();
    mystepper.runToPosition();
    mystepper.moveTo(0);
    mystepper.setAcceleration(20);
  else if(dist>150){
    mystepper.run();
Please read the documentation on Accelstepper .run()
