This program on NodeMCU listens to the UDP port and takes the string from the incoming packet.
Using strcmp()
, I compare the string in the packet. I expect the output of strcmp()
to be 0 when it matches but it doesn't. I printed the value when I sent true in the packet and it was compared with true, it showed 10 instead of 0.
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
const char* ssid = "ESP8266-Access-Point";
const char* password = "123456789";
WiFiUDP Udp;
unsigned int localUdpPort = 4210; // local port to listen on
char incomingPacket[255]; // buffer for incoming packets
char replyPacket[] = "Got message successfully!"; // a reply string to send back
Serial.printf("Connecting to %s ", ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println(" connected");
Udp.begin(localUdpPort);
Serial.printf("Now listening at IP %s, UDP port %d\n", WiFi.localIP().toString().c_str(), localUdpPort);
pinMode(LED_BUILTIN, OUTPUT);
int packetSize = Udp.parsePacket();
if (packetSize) {
// receive incoming UDP packets
Serial.printf("Received %d bytes from %s, port %d\n", packetSize, Udp.remoteIP().toString().c_str(), Udp.remotePort());
int len = Udp.read(incomingPacket, 255);
if (len > 0) {
incomingPacket[len] = 0;
Serial.printf("UDP packet contents:%s\n", incomingPacket);
if(strcmp(incomingPacket, "true")==10) {
Serial.println("on");
digitalWrite(LED_BUILTIN, LOW); // turn led ON
else if(strcmp(incomingPacket, "false")==10) {
Serial.println("off");
digitalWrite(LED_BUILTIN, HIGH); //turn led OFF
// send back a reply, to the IP address and port we got the packet from
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write(replyPacket);
Udp.endPacket();
Serial.println("Reply sent");
receiver.ino (1.63 KB)
