typedef struct
byte None;
byte Up;
byte Down;
} TriggerModes;
typedef struct
TriggerModes Direction;
unsigned long TriggerTime;
} PIRTrigger;
PIRTrigger Trig;
This line of code is in the setup() and is giving me this error
Trig.Direction = TriggerModes.None;
error: expected primary-expression before '.' token
Is the first meant to be an enum
TriggerModes.None is a byte
Trig.Direction is a struct.
amongst other things, you cannot do a direct assignement.
I suspect that, instead of a struct TriggerModes, you want an enum.
yep, sorry everyone.. time for some sleep
