Using structures
I am trying to understand structures.
The attached sketch flashes a LED on pin 13.
I initially thought line 51 should have been:
boolean CheckTime(makeTimer *thisTimer)
Why does this not work?
This makes it work:
boolean CheckTime(struct timer *thisTimer) //<<<<<<<<<<<<<<< LINE 51 >>>>>>>>>>>>
//Blink without Delay skeleton (using structures)
//LarryD
typedef struct timer
  unsigned long lastMillis;
  unsigned long waitMillis;
  boolean       restart;
  boolean       enableFlag;
}makeTimer;
makeTimer pin13 =
  0, 200, true, true
  pinMode(13, OUTPUT);
} //  >>>>>>>>>>>>>> E N D  O F  s e t u p ( ) <<<<<<<<<<<<<<<<<
  //toggle pin 13 200ms
  if (CheckTime(&pin13))
    //toggle pin 13
    digitalWrite(13,!digitalRead(13));
    //if you only want this section of code to happen once
    //uncomment the next line
    //pin13.enableFlag = false;
} //  >>>>>>>>>>>>>> E N D  O F  l o o p ( ) <<<<<<<<<<<<<<<<<
//                      F U N C T I O N S
//Delay time expired function
//lastMillis = time we started
//waitMillis = delay in mS
//restart    = do we start again
//enableFlag = is this timer enabled
  //is the time up for this task?
  if (thisTimer->enableFlag && millis() - thisTimer->lastMillis >= thisTimer->waitMillis)
    //should this start again?
    if(thisTimer->restart)
      //get ready for the next iteration
      thisTimer->lastMillis += thisTimer->waitMillis;  //get ready for the next iteration
    return true;
  return false;
} // END of CheckTime()
//                      E N D  O F  C O D E
When you make up a name : int numberOfGreenApples = 9 ;
Then the 'int' is the type and the 'numberOfGreenApples' is the name of the variable.
For prototyping you can use 'int', but not 'numberOfGreenApples'.
This is good prototyping : void MakeAppleSauce ( int x ) ;
This is wrong prototyping : void MakeAppleSauce ( numberOfGreenApples x ) ;
To avoid confusion, I like to add 'STRUCT' after the type of the struct.
struct myTimerSTRUCT
  boolean       restart;
  boolean       enableFlag;
} myTimer;
The 'myTimerSTRUCT' is the type, it can be used just as an 'int' or 'float'.
The 'myTimer' is the name of a variable that you make up yourself.
The "typedef" keyword is no longer needed for a struct. It is automatically assumed that 'myTimerSTRUCT' is a typedef.
When you do this prototyping : boolean CheckTime(makeTimer *thisTimer) ;
It is the same as : boolean CheckTime ( numberOfGreenApples * thisTimer ) ;
They are both wrong of course.
You know that structures can have methodes just like classes?
You can get rid of all the thisTimer-> stuff.
  boolean       restart;
  boolean       enableFlag;
  boolean       CheckTime();
} makeTimer;
boolean timer::CheckTime()
  if (enableFlag && millis() - lastMillis >= waitMillis)
    if (restart)
      lastMillis += waitMillis;  //get ready for the next iteration
    return true;
  return false;
  if (pin13.CheckTime())
Yes.
The only real difference between a class and a struct is that by default in a class, members are private, but in a struct they're public.
Groove:
Yes.
Did not know that.
Once you do that, I fail to see the benefit of keeping with the struct concept. If you want a class (data and methods), make a class. If you want a struct (data only), make a struct.
LarryD's problem would go away if the struct was properly defined in a header file.
Thanks for all the replies.
Very much appreciated.
I was trying to use a struct with data only in my example.
I have "A Book on C" page 410 that states:
typedef struct {
float re;
float im;
} complex;
complex a, b, c[100];
I took this to mean complex was a/the new type and a tag name after struct was not needed.
would be similar to
int a, b, c[100];
My guess is things have changed and the book is no longer accurate.
@Whandall
I had thought C struct was for data only and it was C++ that introduced methods to data to create class.
Perhaps that's the way it was in the original version form K&R.
Time to get a C++ book.
LarryD:
typedef struct {
float re;
float im;
} complex;
would be similar to
int a, b, c[100];
@Whandall
No, the book is 100% correct, but you did not duplicate what is given in the example in the book. You defined a struct, while the book defined a typedef - two different things. typedef defines a new type (similar to int, float, etc.). The example in the book defines a new type that happens to be a struct. In general, you're probably better off using typedef when defining structs, so you get the benefits of type-checking and, arguably, cleaner syntax when you use the new type.
Regards,
Ray L.
Thanks Ray
"LarryD's problem would go away if the struct was properly defined in a header file."
Thanks PaulS
OK this works see line 135:
boolean CheckTime(timers *thisTimer)
struct _timers
  bool       restart;
  bool       enableFlag;
typedef struct _timers timers;
//LarryD
#include "header.h"
timers pin13 =
  0, 200, true, true
timers pin12 =
  0, 3000, true, true
timers pin11 =
  0, 10000, true, true
timers pin10 =
  0, 6000, true, true
timers Toggle10 =
  0, 50, true, true
timers checkSwitches =
  0, 50, true, true
byte lastMySwitchState       = 1;
byte counter                 = 0;
const byte mySwitch = 2;
  pinMode(12, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(9,  OUTPUT);
  pinMode(mySwitch, INPUT_PULLUP);
    //toggle pin 13
  //after 3 seconds, pin 12 goes and stays HIGH
  if (CheckTime(&pin12))
    //toggle pin 12
    digitalWrite(12,!digitalRead(12));
    pin12.enableFlag = false;
  //pin 11 is HIGH for 10 seconds, then goes and stays LOW
  if (pin11.enableFlag && !CheckTime(&pin11))
    digitalWrite(11,HIGH);
  //10 seconds is now up, go LOW
    digitalWrite(11,LOW);
    //disable above code
    pin11.enableFlag = false;
  //for 6 seconds, toggle pin 10
  if (pin10.enableFlag && !CheckTime(&pin10))
    //toggle pin 10 every 50mS
    if(CheckTime(&Toggle10))
      digitalWrite(10,!digitalRead(10));
  //6 seconds is now up, stop toggling
    digitalWrite(10,LOW);
    //disable
    pin10.enableFlag = false;
  //is it time to check the switches?
  if (CheckTime(&checkSwitches))
    Switches();
  //put other non-blocking stuff here
boolean CheckTime(timers *thisTimer) // <<<<<<<<<<<<<<   LINE 135  >>>>>>>>>>
    return true;
  return false;
//switches are checked every Switches.waitMillis milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void Switches()
  //re-usable for all the switches
  boolean thisState;
  //check if this switch has changed state
  thisState = digitalRead(mySwitch);
  if (thisState != lastMySwitchState)
    //update the switch state
    lastMySwitchState = thisState;
    //this switch position has changed so do some stuff
    //"HIGH condition code"
    //switch goes from LOW to HIGH
    if(thisState == HIGH)
      //example: LED on pin 9 is Push ON, Push OFF
      digitalWrite(9,!digitalRead(9));
    //"LOW condition code"
    //switch goes from HIGH to LOW
      //example: display the current switch push count
      Serial.println(++counter);
  } //END of mySwitch code
  //similar code for other switches goes here
} //END of Switches()
The simpler, more concise, more readable way to both declare the structure, and the typedef would be:
typedef struct
  bool       restart;
  bool       enableFlag;
} timers;
timers pin13 =
  0, 200, true, true
Regards,
Ray L.
@RayLivingston
Yes, I would then have to use:
boolean CheckTime(struct timers *thisTimer) // <<<<<<<<<<<<<< LINE 135 >>>>>>>>>>
When I use a header file as in post #8:
I would not need the word "struct" as below
I like your suggestion, then I would not need the header file.
Just trying to understand the in and outs :o
