Using Switch Case Statements
Hello, I have the following code
#include <SoftwareSerial.h>
#include <Servo.h>
#define relay 8
#define ESC 9
Servo steering;
SoftwareSerial HC12(2,3);
    HC12.begin(9600);
    steering.attach(10);
   if(Serial.available()>1){
     int val=HC12.read();
     switch (val){
       case a:
         analogWrite(ESC,250);
         digitalWrite(relay, HIGH);
       case b:
         analogWrite(ESC, 204);
       case c:
         analogWrite(ESC,153);
         digitalWrite(relay,HIGH);
       case d:
         analogWrite(ESC,102);
       case e:
         analogWrite(ESC,51);
       case f:
         analogWrite(ESC,0);
         digitalWrite(relay,LOW);
       case g:
       case h:
       case i:
       case j:
         analogWrite(ESC,204);
       case k:
         analogWrite(ESC,255);
and it doesn’t compile because it thinks the letters are integers which were not declared. Is there anyway I can still use the letters in my cases? Or should I just use numbers instead? Or maybe a series of if statements? Any other ideas?
case 'a':etc?
Thank you
Adding break statements to your switch could be useful.
Whandall:
Probably essential.
I'm curious what the variables a through k are and where are they defined. Also, case statement blocks do not need a set of braces:
  • case a:*
  • analogWrite(ESC,250);*
  • digitalWrite(relay, HIGH);*
  • break; // Probably needed as Whandall pointed out*
If you want to "use letters" for your cases, you need to define the variables a through k in your program. Their values must equal val for that case to be executed. I would also suggest a default statement block for those values that are not covered:
  • default:*
  • Serial.print("I shouldn't be here. val equals: ");*
  • Serial.println(val);*
  • break;*
econjack:
No, that is not allowed - a through k would have to be consts
Hello,
I’m new in Arduino,
I made this Sketch and it is not working, can anyone help me what to use as three line encoder?
#define SWITCH(a,b,c) switch(a + b<<3 + c<<4)
#define CASE(a,b,c) case(a + b<<3 + c<<4)
int buttonPin2 = 2;
int buttonPin3 = 3;
int buttonPin4 = 4;
Serial.println(“start…”);
pinMode(buttonPin2, INPUT);
pinMode(buttonPin3, INPUT);
pinMode(buttonPin4, INPUT);
int a = digitalRead(buttonPin2);
int b = digitalRead(buttonPin3), c = digitalRead(buttonPin4);
int x = 8;
SWITCH(a,b,c)
CASE(0,0,0):
x=0;
CASE(1,0,0):
x=1;
/*CASE(0,1,0):
x=2;
CASE(0,0,1):
x=3;
CASE(1,1,0):
x=4;
CASE(1,0,1):
x=5;
CASE(0,1,1):
x=6;
Serial.println(x);
Cases have to be compile-time constants
I'm surprised that code compiles
switch/case takes a single integer as its argument.
You are trying to use 3
Oh wait, a,b,c are the macro arguments as well.
Hmm
I hate the phrase "it is not working" - what do you mean?
Also, I'm not sure why you're spreading single bits quite so wide.
You do not need a switch for a simple binary display.
const byte buttonPin2 = 2;
const byte buttonPin3 = 3;
const byte buttonPin4 = 4;
  Serial.println("start...");
  Serial.println(digitalRead(buttonPin2) | (digitalRead(buttonPin3) << 1) | (digitalRead(buttonPin4) << 2));
