Dear forks,
I’m trying to count input pulse by using TC capture function.
But I found strange behavior.
Please look at the code.
If you have DUE, you can try this.
(connect DigitalPin7 to DigitalPin30)
Why does first line show zero ?
It must be one.
thanks.
— head of result ----
hello world
0
1
2
3
4
5
// connect DigitalPin7 to DigitalPin30
static void startTC8() { // pulse capture counter
// TCLK8 PD9 Peri-B
uint32_t maskbit = 1 << 9;
PIOD->PIO_PDR = maskbit; // enables peripheral control of the pin
PIOD->PIO_ABSR |= maskbit; // Assigns the I/O line to the Peripheral B function
pmc_enable_periph_clk(ID_TC8);
TC2->TC_CHANNEL[2].TC_CCR =
TC_CCR_CLKDIS; // disables the clock
TC2->TC_CHANNEL[2].TC_CMR =
TC_CMR_TCCLKS_XC2 | // == TCLK8
0; // CLKI: rising edge of the clock
TC_CCR_CLKEN | // enables the clock if CLKDIS is not 1
TC_CCR_SWTRG; // the counter is reset and the clock is started
Serial.begin(57600);
pinMode(7,OUTPUT);
digitalWrite(7,LOW);
startTC8();
Serial.println("hello world");
digitalWrite(7,HIGH);
delay(2);
Serial.println(TC2->TC_CHANNEL[2].TC_CV,DEC);
You seem to understand a good amount about the timers and their registers on the Due AT91SAM3X8E processor. I've found little documentation about the code needed to modify these timers. Any help or information you can provide would be especially useful.
Thanks elevine,
I read your post and I got Atmel Software Framework (ASF).
But unfortunately I have not gotten exact answer yet.
It seems that people usually use TC capture mode with TC_RAx and/or TC_RBx.
I want to count input pulse simply with only TC_CVx.
In page 873 of the doc11057.pdf,(37.6 Functional Description\37.6.2 32-bit Counter)
"The current value of the counter is accessible in real time by reading the Counter Value Register,
TC_CV. The counter can be reset by a trigger. In this case, the counter value passes to
0x0000 on the next valid edge of the selected clock."
Thanks jt6245,
it seems that first positive edge after "TC2->TC_CHANNEL[2].TC_CCR = TC_CCR_CLKEN |TC_CCR_SWTRG;" clears the TC_CV register. I feel uncomfortable about this specification.
regards,
