Using temp senor to control LED
I keep getting these errors:
In function ‘void loop()’:
error: ‘getVoltage’ was not declared in this scope
error: ‘pin’ was not declared in this scope
error: return-statement with a value, in function returning ‘void’ [-fpermissive] error: ‘else’ without a previous ‘if’
I was trying tio design a project that Blinks an LED when the temperature of a temperature sensor is at or below room temperature for more than 5 seconds and if the temperature exceeds room temperature for more than 5 seconds, the LED will turn off.
Code:
const int BLED = 9;
const int TEMP = 0;
const int LOWER=70;
const int HIGHER=71;
int val = 0;
pinMode(BLED, OUTPUT);
float voltage, degreesC, degreesF;
voltage = getVoltage(val);
degreesC= (voltage -0.5) * 100;
degreesF= degreesC * (9/5) + 32;
Serial.print("voltage: “);
Serial.print(voltage);
Serial.print(” deg C: “);
Serial.print(degreesC);
Serial.print(” deg F: ");
Serial.print(degreesF);
float getVoltage(int pin);
val = analogRead(TEMP);
return (analogRead(pin) * 0.004882814);
if (val >= LOWER);
delay(5000);
digitalWrite(BLED, HIGH);
digitalWrite(BLED, LOW);
if (val < HIGHER)
delay(5000);
(deleted)
