Using TFT and Neopixel at the same time
bodmer:
@MagicD48
Post a copy of your latest sketch so I can suggest mods.
I have removed a lot of the tat that you don't need to bother with. Might be some irrelevant stuff still in there though. Also, sorry for the VERY slow reply, I've been off this part of the project for quite some time. It was stressing me out.
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <ILI9341_due_config.h>
#include <ILI9341_due.h>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int pos = 0;    // variable to store the servo position
#define TFT_RST 8 // uncomment if you have ILI9340
#define TFT_DC 9 // Command/Data for LCD
#define TFT_CS 10 // Chip Select for LCD
#define SD_CS 4 // Chip Select for SD card
#define BUFFPIXELCOUNT 160 // size of the buffer in pixels
#define SD_SPI_SPEED SPI_HALF_SPEED // SD card SPI speed, try SPI_FULL_SPEED
boolean stop = false;
boolean odstop = true;
int inPin = 7;
int inPin1 = 53;
int val = 0;
int incomingByte;      // a variable to read incoming serial data into
SdFat sd; // set filesystem
SdFile bmpFile; // set filesystem
//ArduinoOutStream cout(Serial);
//ILI9341_due tft = ILI9341_due(TFT_CS, TFT_DC); //ILI9341
ILI9341_due tft = ILI9341_due(TFT_CS, TFT_DC, TFT_RST); //ILI9340
// store error strings in flash to save RAM
#define error(s) sd.errorHalt_P(PSTR(s))
  pinMode (53, INPUT);
 tft.begin();
 //tft.setSPIClockDivider(4);
 progmemPrint(PSTR("Initializing SD card..."));
 if (!sd.begin(SD_CS, SD_SPI_SPEED)){
 progmemPrintln(PSTR("failed!"));
 return;
 progmemPrintln(PSTR("OK!"));
  tft.setRotation(iliRotation90);
  digitalWrite (53, HIGH);
  val = digitalRead(53); { // read input value of sWITCH
        if (val == HIGH) {
         stop = true;
         odstop = true;
        else {
         stop = false;
         odstop = false;
  if (stop == true)
     WhoYa();
  else if (stop == false)
      Overdrive();
void Overdrive() {
    bmpDraw("OD_1.565", 0, 0);
    if (odstop) return;
    bmpDraw("OD_2.565", 0, 0);
    if (odstop) return;
    bmpDraw("OD_3.565", 0, 0);
    if (odstop) return;
    bmpDraw("OD_4.565", 0, 0);
    if (odstop) return;
    bmpDraw("OD_5.565", 0, 0);
    if (odstop) return;
    bmpDraw("OD_6.565", 0, 0);
    if (odstop) return;
    bmpDraw("OD_7.565", 0, 0);
    if (odstop) return;
    bmpDraw("OD_8.565", 0, 0);
    if (odstop) return;
    bmpDraw("OD_9.565", 0, 0);
    if (odstop) return;
    bmpDraw("OD_18.565", 0, 0);
    if (odstop) return;
    if (odstop) return;
    bmpDraw("OD_19.565", 0, 0);
    if (odstop) return;
    if (odstop) return;
    bmpDraw("OD_20.565", 0, 0);
    if (odstop) return;
    if (odstop) return;
    bmpDraw("OD_21.565", 0, 0);
    if (odstop) return;
    if (odstop) return;
    bmpDraw("OD_22.565", 0, 0);
    if (odstop) return;
void WhoYa() {
  bmpDraw("WYGC1.565", 0, 0);
  bmpDraw("WYGC2.565", 0, 0);
  bmpDraw("WYGC3.565", 0, 0);
  bmpDraw("WYGC4.565", 0, 0);
  bmpDraw("WYGC5.565", 0, 0);
  bmpDraw("WYGC7.565", 0, 0);
  bmpDraw("WYGC9.565", 0, 0);
  bmpDraw("WYGC10.565", 0, 0);
  bmpDraw("WYGC11.565", 0, 0);
  bmpDraw("WYGC12.565", 0, 0);
  bmpDraw("WYGC13.565", 0, 0);
  bmpDraw("WYGC14.565", 0, 0);
  bmpDraw("WYGC15.565", 0, 0);
  bmpDraw("WYGC16.565", 0, 0);
// This function opens a Windows Bitmap (BMP) file and
// displays it at the given coordinates.  It's sped up
// by reading many pixels worth of data at a time
// (rather than pixel by pixel).  Increasing the buffer
// size takes more of the Arduino's RAM but
// makes loading a little faster.
void bmpDraw(const char* filename, int x, int y) {
 SdFile   bmpFile;
 int      bmpWidth, bmpHeight;   // W+H in pixels
 uint8_t  bmpDepth;              // Bit depth (currently must be 24)
 uint8_t headerSize;
 uint32_t bmpImageoffset;        // Start of image data in file
 uint32_t rowSize;     // Not always = bmpWidth; may have padding
 uint32_t fileSize;
 boolean  goodBmp = false;       // Set to true on valid header parse
 boolean  flip = true;        // BMP is stored bottom-to-top
 uint16_t w, h, row, col;
 uint8_t  r, g, b;
 uint32_t pos = 0, startTime;
 if ((x >= tft.width()) || (y >= tft.height())) return;
 progmemPrint(PSTR("Loading image '"));
 Serial.print(filename);
 Serial.println('\'');
 startTime = millis();
 // Open requested file on SD card
 if (!bmpFile.open(filename, O_READ)) {
 Serial.println("File open failed.");
 return;
 else {
 //Serial.println("File opened.");
 // Parse BMP header
 if (read16(bmpFile) == 0x4D42) { // BMP signature
 fileSize = read32(bmpFile);
 //progmemPrint(PSTR("File size: ")); Serial.println(fileSize);
 (void)read32(bmpFile); // Read & ignore creator bytes
 bmpImageoffset = read32(bmpFile); // Start of image data
 //progmemPrint(PSTR("Image Offset: ")); Serial.println(bmpImageoffset, DEC);
 // Read DIB header
 headerSize = read32(bmpFile);
 //progmemPrint(PSTR("Header size: ")); Serial.println(headerSize);
 bmpWidth = read32(bmpFile);
 bmpHeight = read32(bmpFile);
 if (read16(bmpFile) == 1) { // # planes -- must be '1'
 bmpDepth = read16(bmpFile); // bits per pixel
 //progmemPrint(PSTR("Bit Depth: ")); Serial.println(bmpDepth);
 if (read32(bmpFile) == 0) // 0 = uncompressed
 //progmemPrint(PSTR("Image size: "));
 //Serial.print(bmpWidth);
 //Serial.print('x');
 //Serial.println(bmpHeight);
 // If bmpHeight is negative, image is in top-down order.
 // This is not canon but has been observed in the wild.
 if (bmpHeight < 0) {
 bmpHeight = -bmpHeight;
 flip = false;
 // Crop area to be loaded
 w = bmpWidth;
 h = bmpHeight;
 if ((x + w - 1) >= tft.width())  w = tft.width() - x;
 if ((y + h - 1) >= tft.height()) h = tft.height() - y;
 // Set TFT address window to clipped image bounds
 tft.setAddrWindow(x, y, x + w - 1, y + h - 1);
 if (bmpDepth == 16) //565 format
 goodBmp = true; // Supported BMP format -- proceed!
 uint16_t buffer[BUFFPIXELCOUNT]; // pixel buffer
 bmpFile.seekSet(54); //skip header
 uint32_t totalPixels = (uint32_t)bmpWidth*(uint32_t)bmpHeight;
 uint16_t numFullBufferRuns = totalPixels / BUFFPIXELCOUNT;
 for (uint32_t p = 0; p < numFullBufferRuns; p++) {
 // read pixels into the buffer
 bmpFile.read(buffer, 2 * BUFFPIXELCOUNT);
 // push them to the diplay
 tft.pushColors(buffer, 0, BUFFPIXELCOUNT);
 // render any remaining pixels that did not fully fit the buffer
 uint32_t remainingPixels = totalPixels % BUFFPIXELCOUNT;
 if (remainingPixels > 0)
 bmpFile.read(buffer, 2 * remainingPixels);
 tft.pushColors(buffer, 0, remainingPixels);
 progmemPrint(PSTR("Unsupported Bit Depth."));
 if (goodBmp)
 progmemPrint(PSTR("Loaded in "));
 Serial.print(millis() - startTime);
 Serial.println(" ms");
 bmpFile.close();
 if (!goodBmp) progmemPrintln(PSTR("BMP format not recognized."));
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(SdFile& f) {
 uint16_t result;
 ((uint8_t *)&result)[0] = f.read(); // LSB
 ((uint8_t *)&result)[1] = f.read(); // MSB
 return result;
uint32_t read32(SdFile& f) {
 uint32_t result;
 ((uint8_t *)&result)[2] = f.read();
 ((uint8_t *)&result)[3] = f.read(); // MSB
 return result;
// Copy string from flash to serial port
// Source string MUST be inside a PSTR() declaration!
void progmemPrint(const char *str) {
 char c;
 if (c = pgm_read_byte(str++)) Serial.print(c);
// Same as above, with trailing newline
void progmemPrintln(const char *str) {
 progmemPrint(str);
 Serial.println();
