using the arduino IDE and compiler , but not the arduino bootloader .
hello .
I want to suttle with the SPI programming , so i will use an arduino uno as an SPI programmer .
what i need , is to use the arduino IDE and compiler to write code for an atmega1284 .
i was using AVR studio . but the arduino IDE is much lighter and better for programming .
how can i do this ?
By selecting File -> Upload Using Programmer. But I have no idea if the ATmega1284 is supported. Otherwise you have to create your own "board" to make it work.
how can i write my own "board" ?
Instead, why not find an Arduino that uses the 1284, and select that?
i dont think there is one though.
any good documentations on how to write files for the arduino to add support for avr chips ?
amine2:
You are wrong. Search for it (there isn't an "official" Arduino 1284, but the support files exist).
I still use this with 1.0.6
Haven't looked into what's needed for 1.6.x lately.
CrossRoads:
GitHub - JChristensen/mighty-1284p: Mighty 1284P Platform for Arduino
Don't think the IDE update affects it (it was recognized as "legacy board"). I'm using 1.6.5 with 1284P OSPL variant, pretty much a renamed Bobuino variant to take some credit :smiley:
OP,
I recommend using the Bobuino variant/mapping scheme. It works like UNO only with more pins and memory.
Also, do you have a dev board with 1284P? Bobuino would be a natural choice. If I didn't design my own boards, I'd be using those.
