Using the Arduino Nano V3 as FTDI
This is my first post so please be gentle if I am not in the right forum :smiley:
I have a Arduino Nano V3 that I used a USBasp to load the boot loader. All went well on my mac.
Now I want to use the Arduino Nano as an FTDI breakout to program an STM32 device because my FTDI is 2 weeks away. I wired as Follows:
Nano Target FTDI
J1:TX -------- Pin 3: RX
J2:RX ------- Pin 2: TX
J27:5V ------ Pin 4: VCC
J29: GND --- Pin 6: GND
I used cool term to connect and am getting data but it is not responding correctly. My questions are:
  1. Did I wire it correctly?
  2. Does the FTDI communicate directly when wired this way or do I need to eliminate the atmega 328 from the circuit? I cannot remove it, it is soldered in. Should I ground the reset or is there a sketch available to do this?
Everything I read seems to suggest this should work as is but would like conclusive confirmation.
What is TX on the Nano? The ATmega TX pin? In this case you have to cross TX/RX.
I did as shown in the pinout to standard FTDI connector above.
skripo:
Nano Target FTDI
Members
I know its an old post but is this possible to use a NANO as FTDI to upload a sketch? Ive got a FTDI1703-C on my NANO board.
