I've found the bounce library on the Arduino website. Am I right in thinking I can use this as a neater way of coding a debounce? It does the same thing but I don't need to clutter my sketch with the debounce code, it's in the library? I'm using it like this:-
// Includes
#include <Bounce.h>
// Definitions
#define NurseryButt 2
#define NurseryLED 4
#define DoorbellButt 3
#define DoorbellLED 5
// Instantiate a Bounce object with a 3 millisecond debounce time
Bounce nursery = Bounce( NurseryButt,2 );
Bounce doorbell = Bounce( DoorbellButt,2 );
pinMode(NurseryButt,INPUT);
pinMode(NurseryLED,OUTPUT);
pinMode(DoorbellButt,INPUT);
pinMode(DoorbellLED,OUTPUT);
// Update the debouncer
nursery.update ( );
doorbell.update ( );
// Get the update value
int nurseryvalue = nursery.read();
int doorbellvalue = doorbell.read();
// Turn on or off the Nursery lamp
if ( nurseryvalue == HIGH) {
digitalWrite(NurseryLED, HIGH );
digitalWrite(NurseryLED, LOW );
// Turn on or off the doorbell lamp
if ( doorbellvalue == HIGH) {
digitalWrite(DoorbellLED, HIGH );
digitalWrite(DoorbellLED, LOW );
Does that look right? i.e. create a whole new load of bounce objects and debouncer values etc for every input?
Ignore that, it's just from not having updated the comment when I was trying to get rid of the flicker. Surely I need a certain minimum for the debounce routine to be effective?
Sure. You are talking about a real contact caused by a human vs. contact bounce caused my mechanical issues in the switch itself. A debounce time of 50 milliseconds would likely be better.
It's hard for people to press, release, and press again in that period of time. And, if they do, do you really want to count that as two presses?
Thanks. That sounds good. But won't that result in massive LED flickering? At 5ms it was noticeably flickering, when I reduced it to 2ms it was "almost" like a constant. I probably have an error in my code wouldn't you say?
I'd say it is more likely that you do not have your switches wired correctly. You are not using the internal pullup resistors, so external pullup or pulldown resistors are needed. How ARE your switches wired?
Bad boy! No desert for you. You'll need to save that money to buy a new Arduino.
I have the switch between two things. Ground and an input pin.
So, when the switch is not pressed, the pin is floating, and when it is pressed, the pin is connected to ground. The "when pressed" part is OK. The "when not pressed" part is not.
PaulS:
Eek...hope not. Was just trying to save time when prototyping (I see it was false economy now). What do you think could have damaged the arduino?
So, when the switch is not pressed, the pin is floating[/quote]
Coudl this explain the flickering LED? The thing is, it never flickers when the switch is off...only when it's on?
So I guess I have a potential board failure to look forward to?
Probably not immediately, and only for the pins that the LEDs were connected to. The good news is that a new chip is only $6 at Sparkfun. No need to replace the whole board (unless you have the SMD version).
