I’m attempting to find if the difference between two potentiometers is increasing or decreasing. To do this I’m using two potentiometers and two LED’s. For some reason the red LED is flickering while the green one stays off. Any help would be greatly appreciated, thank you for your time.
int oldvalue;
int oldvalue = 0;
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
int val = (analogRead(A0) - analogRead(A1)); // take the difference between A0 and A1:
if(val > oldvalue)
digitalWrite(3,HIGH);// the difference between the two POTS is increasing so turn on the RED LED
digitalWrite(3,LOW);// turn off the RED LED
if (val < oldvalue)
digitalWrite(4, HIGH);// the difference between the two POTS is increasing so turn on the RED LED
digitalWrite(4, LOW);// turn off the GREEN LED
// get current value into oldvalue for next comparison
oldvalue = val;
But you’re NOT basing your LED behaviour on the difference of the pots.
It’s based on the difference of the difference since the last itteration of the loop. So if you’re really fast on the pot it’ll turn on a LED for about 20 MICRO seconds.
On the next itteration of the loop, the difference between the two pots will be the same as it was last time, so any leds that are currently alight will be immediately turned off again.
Wave222222:
Your code is much simpler, thanks Nick. I’m still running into the problem where the red LED stays on the entire time.
That’ll be because val is never bigger than oldvalue for more than the odd itteration of the loop here and there as you move it. As soon as you stop moving them, oldvalue will always be the same as val.
