using the EasyTransfer library
HI There
I have been having a pay with the EasyTransfer library between to of my uno, i have two 10k pots on the one which adjust to led brightness on the other uno all works fine :slight_smile:
Here are my sketches:
uno with two pots:
#include <EasyTransfer.h>
EasyTransfer ET;
struct DATA_STRUCTURE{
 int percentage;
 char temp;
DATA_STRUCTURE myData;
int val;
int val2;
 //Initalizing EasyTransfer Serial Ports
 ET.begin(details(myData), &Serial);
//counter = 0;
  val = analogRead(A0);            // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 0, 250);     // scale it to use it with the servo (value between 0 and 180)
  val2 = analogRead(A1);            // reads the value of the potentiometer (value between 0 and 1023)
  val2 = map(val2, 0, 1023, 0, 250);     // scale it to use it with the servo (value between 0 and 180)
 //Setting Values to Variables
 myData.temp       = val;
 myData.percentage = val2;
//Sending Data
 ET.sendData();
And the uno with the two LEDs:
EasyTransfer ET;
 int percentage;
 char temp;
 pinMode(13, OUTPUT);
 pinMode(12, OUTPUT);
 //Extract data if data is received
 if(ET.receiveData())
 delay(250);
 analogWrite(12, myData.percentage);
 analogWrite(13, myData.temp);
Now i would prefer to change the uno with the two LEDs for a Leonardo, up load my sketch and i can not get it to do anything :frowning:
why is this and how can i over come this?
Many thanks
Joe
How are the two Arduino connected? On the Uno, pins 0 and 1 are Serial. Not so on the Leonardo.
PaulS:
pin 0 & 1 to pin 1 & 0
yer i was wondering if the Leonardo had serial pins with out using something like SoftwareSerial?
Pins 0 and 1 on the Leonardo are connected to the Serial1 instance.
i see now :slight_smile:
  Serial1.begin(9600);
 ET.begin(details(myData), &Serial1);
and now it is working :slight_smile:
thanks Pauls
