I’m trying to be able to print jpg images on a thermal printer
Im using a ESP32-WROOM-32D
I have got the thermal printer working by adapting Larry Bank’s thermal printer code to work with a MXW01 printer and can print BMPs successfully. Additionally sending test code I can print using the current code im using so Im confident that part is working.
Testing different test images seems to yield the same result in terms of output being sent to the printer so I’m assuming im not correctly using the JPGDEC library but I can’t see what im doing wrong. THE JPGDEC code is the jpg. lines in the loop and the JPEGDraw function.
Please could someone advice whether im making an obvious mistake or what i should try next in order to debug further
The chekerboard test pattern is stored as a progmem as so it should be a 24Bpp image
// checkerboard_384x486_jpg - 384x486 JPEG, 4493 bytes
const unsigned int checkerboard_384x486_jpg_len = 4493;
const unsigned char checkerboard_384x486_jpg[] PROGMEM = {
0xFF, 0xD8, 0xFF, 0xE0, 0x00, 0x10, 0x4A, 0x46, 0x49, 0x46, 0x00, 0x01,
0x01, 0x00, 0x00, 0x01, 0x00, 0x01, 0x00, 0x00, 0xFF, 0xDB, 0x00, 0x43,
0x00, 0x02, 0x01, 0x01, 0x01, 0x01, 0x01, 0x02, 0x01, 0x01, 0x01, 0x02,
0x02, 0x02, 0x02, 0x02, 0x04, 0x03, 0x02, 0x02, 0x02, 0x02, 0x05, 0x04,
0x04, 0x03, 0x04, 0x06, 0x05, 0x06, 0x06, 0x06, 0x05, 0x06, 0x06, 0x06,
0x07, 0x09, 0x08, 0x06, 0x07, 0x09, 0x07, 0x06, 0x06, 0x08, 0x0B, 0x08,
0x09, 0x0A, 0x0A, 0x0A, 0x0A, 0x0A, 0x06, 0x08, 0x0B, 0x0C, 0x0B, 0x0A,
this is my code
#include <Thermal_Printer.h>
#include <JPEGDEC.h>
#include "eagle_576.h"
#include "dog_384.h"
uint8_t ucDither[576 * 16]; // buffer for the dithered pixel output
JPEGDEC jpg;
static int iWidth;
int JPEGDraw(JPEGDRAW *pDraw)
Serial.print(" W: "); Serial.print(pDraw->iWidth);
Serial.print(" H: "); Serial.println(pDraw->iHeight);
// Optional: inspect a few pixel bits
for (int i = 0; i < 16 && i < (pDraw->iWidth * pDraw->iHeight / 8); i++) {
Serial.print("0x");
Serial.print(pDraw->pPixels[i], HEX);
Serial.print(" ");
tpSetBackBuffer((uint8_t *)pDraw->pPixels, pDraw->iWidth, pDraw->iHeight);
tpSendImageData();
return 1;
while (!Serial);
Serial.println((char *)"Scanning for BLE printer");
if (tpScan()) // Scan for any supported printer name
Serial.println((char *)"Found a printer!, connecting...");
if (tpConnect())
Serial.println("Connected!");
tpSetWriteMode(MODE_WITHOUT_RESPONSE);
Serial.println("Failed to connected :(");
while (1) {};
} // if scan
Serial.println((char *)"Didn't find a printer :( ");
while (1) {};
} /* setup () */
uint8_t *pImage;
int iImageSize;
pImage = (uint8_t *)dog_384;
iImageSize = (int)sizeof(dog_384);
tpPreGraphics(384,486);
if (jpg.openRAM(pImage, iImageSize, JPEGDraw)) {
jpg.setPixelType(ONE_BIT_DITHERED);
jpg.decodeDither(ucDither, 0);
tpPostGraphics();
tpFeed(32); // advance the paper 32 scan lines
tpDisconnect();
Serial.println("Finished printing!");
while (1) {};
} /* loop() */
