I have the latest version of the IRremote library installed. I am using a SAMSUNG remote. I cannot use this function receiver.decode(&results). I have to use receiver.decode(). For the "1" button on my SAMSUNG remote, the hex value is E0E020DF. Which command do I use to tell if the received IR is that value?
What data type is the E0E020DF ?
Is it an integer, an array of chars or a String ?
Please post a sketch that illustrates reading the value
Try IrReceiver.decodedIRData.address (0xE0E0) and IrReceiver.decodedIRData.command (0x20DF)
Sample:
if (IrReceiver.decode() && IrReceiver.decodedIRData.protocol == SAMSUNG) {
Serial.print((char)IrReceiver.decodedIRData.command);
IrReceiver.resume();
Further information:
I tried this:
#include <IRremote.h>
int irrecv_pin = A0;
IRrecv receiver(irrecv_pin);
receiver.enableIRIn();
if (receiver.decode() && receiver.decodedIRData.protocol == SAMSUNG) {
Serial.println(receiver.decodedIRData.command);
receiver.resume();
Things were going fine until it stopped receiving IR signal. All the wirings are done correctly. The remote has enough battery power as tested from the multimeter. When I press any buttons on the remote, it does not receive any signal.
Here you can see a running example: sketch.ino - Wokwi Arduino and ESP32 Simulator
With the Wokwi simulation only the NEC protocol works.
Replace in your program NEC by SAMSUNG. Then it should also work with a Samsung remote control.
I have used the digital pin 2 for the example. No analog pin.
I tried it and it works fine. Thank you for the help.
Great. Then it would be nice if you mark the thread as solved.
