Using the MCP3201 12 Bit ADC with the Arduino DUE
There are a few differences in the code for the new DUE, with regards to how to program SPI communications. I spent the day learning to work with the DUE and the new “extended SPI library”.
Here’s working code, fully commented, that will get you up and running if you are wanting to interface an MCP3201 to the DUE…
// Gregg Messenger      December 18, 2014
// This Sketch is for the DUE board and utilizes the "Extended SPI Library" available for the DUE.
// The purpose of this sketch is to read 12 bit data from an MCP3201 12 bit ADC chip and to send it to the serial monitor.
// Note: The DUE is a 32 bit system that uses 3.3v logic.  Don't apply 5 volts to any of the pins on this board!
// Wiring Map
// MCP3201            DUE
// Pin 1 Vref  -->  3.3v (DUE)
// Pin 2 IN+   -->  Center pin of 5k potentiometer
// Pin 3 IN-   -->  GND (DUE)
// Pin 4 Vss   -->  GND (DUE)
// Pin 5 CS    -->  Pin 10 (DUE)
// Pin 6 Dout  -->  MIMO Pin 1 on SPI Header (DUE)
// Pin 7 CLK   -->  SCK Pin 3 on SPI Header (DUE)
// Pin 8 Vdd   -->  3.3v (DUE)
// Left pin on potentiometer goes to Pin 1 (Vref) on MCP3201
// Right pin on potentiometer goes to GND
// Install a decoupling capacitor (.1uF ceramic disc) across pins 2 & 3 on the MCP3201 to eliminate noise on the input.
#include <SPI.h>
unsigned int result = 0;       //Initialize the 32 bit variable used to store the 12 bit value from the MCP3201
byte byteOne = 0;              //Initialize an 8 bit variable to read the first byte from the MCP3201
byte byteTwo = 0;              //Initialize another 8 bit variable to read the second byte
float percent = 0;             //Initialize a float variable to display percentage with capability of decimal places
  Serial.begin(9600);                //Open the serial port at 9600 baud
  SPI.begin(10);                     //Initialize the bus for a device on pin 10
  SPI.setDataMode(10,1);             //Set SPI data mode to 1
  SPI.setBitOrder(10, MSBFIRST);     //Expect the most significant bit first, apply rule only to pin 10
  SPI.setClockDivider(10, 42);       //Set clock divider on pin 10 to 42 (84 MHz / 42 = 2 MHz SPI bus speed)
  byteOne = SPI.transfer(10, 0x00, SPI_CONTINUE);     //Read the first byte from the MCP3201, keep CS active LOW for the next byte to transfer
  byteTwo = SPI.transfer(10, 0x00, SPI_LAST);         //Read the second byte, take CS pin 10 HIGH to disable the MCP3201
  result = byteOne;                                           //Store the first byte into the result variable
  result = result << 8;                                       //Shift the first byte left 8 bits.
  result = result | byteTwo;                                  //Combine the two bytes into a 16 bit word (stored in a 32 bit variable) using OR function
  result = result >> 1;                                       //Shift the bits in the word to the right 1 places.  Bit 0 from MCP3201 is blank data.
  result = result & 0b00000000000000000000111111111111;       //Bit mask the first 20 bits using the AND function.  We only want to look at the last 12 bits
  percent = ((float) result/4096*100);                        //Cast the result integer into a float variable, calculate percentage.
  Serial.println(percent,1);                           //Display the final result using the serial monitor.  1 decimal place.
DUE_MCP3201_ADC.ino (3.04 KB)
