Using the multiplexer with mutiple HX711 load cells
Hi everyone, i am new to Arduino and this is one of my first projects. I have an Arduino 1 connected with a 4x3 keypad, a LCD with I2C and i need to connect to 6 (maybe 8 in the future) HX711 load cells. I do not want to buy an Arduino Mega if it is not necessary and i thought i could use a 16 channels multiplexer but the initialization of the load cells requires the pins for the DT and SCK of the amplifiers and from what i saw it is not feasible since the multiplexer needs to be initialized too.
How can i solve this?
You can connect all HX711 units to share a single clock pin, so then with six units you only need seven pins.
The HX711-multi library helps with this.
Thank you. The clock pin is the DK pin? Which is the limit oh load cell until i ran out of pins and I need another solution? Because I was thinking of another project with 12 load cells.
With 12 HX711's, you'd need 13 pins. The basic UNO has 20 GPIO. If your keypad and LCD use I2C, then neglecting the serial TX/RX pins, you have 16 free. More than enough for 12 HX711s.
