I'm asking for some general advice on my approach, programming and use of correct/best used functions.
I''m returnig for a 3rd session of Ardunio after a 5 year break, in the past my projects never really needed to run fast and were for my own interest, programs were long and messy. I started a project that works as wanted but the program was getting yet again long and messy (looking).
So I've abandond that, and decided to focus on learning and layout, my set up on the breadboard is mega pro mini with Adafruit 160x128 tft and four buttons. All working correctly, I thought I'd like to learn more about the graphic side of things so started a simple Space Invader scetch(just one invader at the mo)
My background is a child of the 60's that paid a months wages for a C64 and taught myself basic, which was very useful as a cnc machinist using logic statements in cnc programs.
My Space Invader program is simple in the use of draw pixels and lines, the Single Invader and base have black pixeks around the outside so they move without blinking, and that seems to work well, for now at least. On the C64 I used PEEK and POKE to read values (seems the same as read and write to the Ardunio EEPROM)
Is there a way to read back from the tft that is faster than logic statements (to detect the colour of the pixel above the bullet)
Should I be using the Progmem function instead of lines and pixels? Or I did read on Adafruit page the use of a canvas with the tft? Advice would be great and taken as Ican't wait to learn and move on to Pac Man
Phil.
int invad_1_pos_x = 10;
int invad_1_pos_y = 50;
int invader_direction = 1;
int base_1_pos_x = 80;
int base_1_pos_y = 116;
int base_bullet_pos_x;
int base_bullet_pos_y;
int base_bullet_fired;
int life = 3;
int score = 0;
int high_score_1;
int button_1; //RIGHT
int button_2; //BLUE ~ FIRE
int button_3; //LEFT
int button_4; //RED
int active_button = 0;
#include <Adafruit_GFX.h>
#include <Adafruit_ST7735.h>
#include <SPI.h>
#include <Wire.h>
#define TFT_CS 42
#define TFT_RST 47 // Or set to -1 and connect to Arduino RESET pin
#define TFT_DC 46 //card_CS white wire 45
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
pinMode(2, INPUT);
pinMode(3, INPUT);
pinMode(4, INPUT);
pinMode(5, INPUT);
tft.initR(INITR_BLACKTAB);
tft.setRotation(1);
tft.fillScreen(ST77XX_BLACK);
tft.setTextColor(ST77XX_GREEN, ST77XX_BLACK);
tft.setCursor(2, 2);
tft.setTextSize(1);
tft.print("Score"); tft.setCursor(36, 2); tft.print(score);
tft.setCursor(110, 2);
tft.print("Lives"); tft.setCursor(144, 2); tft.print(life);
draw_base();
invader_move(); draw_invader();
button_check();
game_logic();
active_button = 0;
if (invad_1_pos_y >= 108 && base_1_pos_x == invad_1_pos_x) {
//tft.setCursor(30, 60);tft.setTextSize(2);tft.println("Game Over");
while (1);
void game_logic() {
if (active_button == 1 && base_1_pos_x < 144) {
base_1_pos_x++; draw_base();
if (active_button == 3 && base_1_pos_x > 2) {
base_1_pos_x--; draw_base();
if (active_button == 2 && base_bullet_fired == 0) {
base_bullet_pos_x = base_1_pos_x + 6; base_bullet_pos_y = base_1_pos_y - 4; base_bullet_fired = 1;
if (base_bullet_fired == 1) {
base_bullet();
void base_bullet() {
if (base_bullet_pos_x + 1 >= invad_1_pos_x && base_bullet_pos_x <= invad_1_pos_x + 11 && base_bullet_pos_y >= invad_1_pos_y && base_bullet_pos_y <= invad_1_pos_y + 8) {
score = score + 42; tft.setCursor(36, 2); tft.print(score);
base_bullet_fired = 0;
tft.drawFastVLine(base_bullet_pos_x, base_bullet_pos_y - 2, 6, ST77XX_BLACK);
tft.fillRect(invad_1_pos_x, invad_1_pos_y , 12, 10, ST77XX_BLACK);
tft.drawFastVLine(base_bullet_pos_x, base_bullet_pos_y - 6, 6, ST77XX_BLACK);
invad_1_pos_x = 10; invad_1_pos_y = 50;
if (base_bullet_pos_y > 12) {
base_bullet_pos_y--;
tft.drawFastVLine(base_bullet_pos_x, base_bullet_pos_y - 2, 4, ST77XX_GREEN);
tft.drawPixel(base_bullet_pos_x, base_bullet_pos_y + 4, ST77XX_BLACK);
else {
void invader_move() {
if (invader_direction == 1 && invad_1_pos_x <= 141) {
invad_1_pos_x++; return;
if (invader_direction == 1 && invad_1_pos_x >= 142) {
invader_direction = 2;
invad_1_pos_x++; invad_1_pos_y++; return;
if (invader_direction == 2 && invad_1_pos_x >= 140) {
invad_1_pos_y++; invader_direction = 0; return;
if (invader_direction == 2 && invad_1_pos_x <= 3) {
invad_1_pos_y++; invader_direction = 1; return;
if (invader_direction == 0 && invad_1_pos_x >= 3) {
invad_1_pos_x--; return;
if (invader_direction == 0 && invad_1_pos_x <= 2) {
invad_1_pos_x--; invad_1_pos_y++; return;
void button_check() {
if (digitalRead(2) == HIGH) {
active_button = 1; return;
if (digitalRead(3) == HIGH) {
active_button = 2; return;
if (digitalRead(4) == HIGH) {
active_button = 3; return;
if (digitalRead(5) == HIGH) {
active_button = 4; return;
void draw_base() {
tft.drawLine(base_1_pos_x + 1, base_1_pos_y + 6, base_1_pos_x + 11, base_1_pos_y + 6, ST77XX_GREEN);
tft.drawLine(base_1_pos_x + 1, base_1_pos_y + 5, base_1_pos_x + 11, base_1_pos_y + 5, ST77XX_GREEN);
tft.drawLine(base_1_pos_x + 2, base_1_pos_y + 4, base_1_pos_x + 10, base_1_pos_y + 4, ST77XX_GREEN);
tft.drawLine(base_1_pos_x + 5, base_1_pos_y + 3, base_1_pos_x + 7, base_1_pos_y + 3, ST77XX_GREEN);
tft.drawLine(base_1_pos_x + 5, base_1_pos_y + 2, base_1_pos_x + 7, base_1_pos_y + 2, ST77XX_GREEN);
tft.drawLine(base_1_pos_x + 6, base_1_pos_y + 0, base_1_pos_x + 6, base_1_pos_y + 1, ST77XX_GREEN);
tft.drawPixel(base_1_pos_x + 0, base_1_pos_y + 6, ST77XX_BLACK);
tft.drawPixel(base_1_pos_x + 0, base_1_pos_y + 5, ST77XX_BLACK);
tft.drawPixel(base_1_pos_x + 1, base_1_pos_y + 4, ST77XX_BLACK);
tft.drawPixel(base_1_pos_x + 4, base_1_pos_y + 3, ST77XX_BLACK);
tft.drawPixel(base_1_pos_x + 4, base_1_pos_y + 2, ST77XX_BLACK);
tft.drawPixel(base_1_pos_x + 5, base_1_pos_y + 1, ST77XX_BLACK);
tft.drawPixel(base_1_pos_x + 5, base_1_pos_y + 0, ST77XX_BLACK);
tft.drawPixel(base_1_pos_x + 7, base_1_pos_y + 0, ST77XX_BLACK);
tft.drawPixel(base_1_pos_x + 7, base_1_pos_y + 1, ST77XX_BLACK);
tft.drawPixel(base_1_pos_x + 8, base_1_pos_y + 2, ST77XX_BLACK);
tft.drawPixel(base_1_pos_x + 8, base_1_pos_y + 3, ST77XX_BLACK);
tft.drawPixel(base_1_pos_x + 11, base_1_pos_y + 4, ST77XX_BLACK);
tft.drawPixel(base_1_pos_x + 12, base_1_pos_y + 5, ST77XX_BLACK);
tft.drawPixel(base_1_pos_x + 12, base_1_pos_y + 6, ST77XX_BLACK);
void draw_invader() {
tft.drawPixel(invad_1_pos_x + 3, invad_1_pos_y + 1, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 9, invad_1_pos_y + 1, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 4, invad_1_pos_y + 2, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 8, invad_1_pos_y + 2, ST77XX_GREEN);
tft.drawLine(invad_1_pos_x + 3, invad_1_pos_y + 3, invad_1_pos_x + 9, invad_1_pos_y + 3, ST77XX_GREEN);
tft.drawLine(invad_1_pos_x + 2, invad_1_pos_y + 4, invad_1_pos_x + 10, invad_1_pos_y + 4, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 4, invad_1_pos_y + 4, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 8, invad_1_pos_y + 4, ST77XX_BLACK);
tft.drawLine(invad_1_pos_x + 1, invad_1_pos_y + 5, invad_1_pos_x + 11, invad_1_pos_y + 5, ST77XX_GREEN);
tft.drawLine(invad_1_pos_x + 3, invad_1_pos_y + 6, invad_1_pos_x + 9, invad_1_pos_y + 6, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 1, invad_1_pos_y + 6, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 1, invad_1_pos_y + 7, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 11, invad_1_pos_y + 6, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 11, invad_1_pos_y + 7, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 3, invad_1_pos_y + 7, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 9, invad_1_pos_y + 7, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 4, invad_1_pos_y + 8, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 5, invad_1_pos_y + 8, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 7, invad_1_pos_y + 8, ST77XX_GREEN);
tft.drawPixel(invad_1_pos_x + 8, invad_1_pos_y + 8, ST77XX_GREEN);
// outside
tft.drawPixel(invad_1_pos_x + 0, invad_1_pos_y + 7, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 0, invad_1_pos_y + 6, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 0, invad_1_pos_y + 5, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 0, invad_1_pos_y + 4, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 1, invad_1_pos_y + 4, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 1, invad_1_pos_y + 3, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 2, invad_1_pos_y + 3, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 2, invad_1_pos_y + 2, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 3, invad_1_pos_y + 2, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 2, invad_1_pos_y + 1, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 2, invad_1_pos_y + 0, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 3, invad_1_pos_y + 0, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 4, invad_1_pos_y + 0, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 4, invad_1_pos_y + 1, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 5, invad_1_pos_y + 1, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 5, invad_1_pos_y + 2, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 6, invad_1_pos_y + 2, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 7, invad_1_pos_y + 2, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 7, invad_1_pos_y + 1, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 8, invad_1_pos_y + 1, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 8, invad_1_pos_y + 0, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 9, invad_1_pos_y + 0, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 10, invad_1_pos_y + 0, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 10, invad_1_pos_y + 1, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 10, invad_1_pos_y + 2, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 9, invad_1_pos_y + 2, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 10, invad_1_pos_y + 3, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 11, invad_1_pos_y + 3, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 11, invad_1_pos_y + 4, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 12, invad_1_pos_y + 4, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 12, invad_1_pos_y + 5, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 12, invad_1_pos_y + 6, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 12, invad_1_pos_y + 7, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 10, invad_1_pos_y + 6, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 10, invad_1_pos_y + 7, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 9, invad_1_pos_y + 8, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 8, invad_1_pos_y + 7, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 6, invad_1_pos_y + 8, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 4, invad_1_pos_y + 7, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 3, invad_1_pos_y + 8, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 2, invad_1_pos_y + 7, ST77XX_BLACK);
tft.drawPixel(invad_1_pos_x + 2, invad_1_pos_y + 6, ST77XX_BLACK);
