Hello, I've been experimenting with the SRF range finder library found here: http://arduino.cc/en/Tutorial/SFRRangerReader.
Here's the SRF code given at that link:
// I2C SRF10 or SRF08 Devantech Ultrasonic Ranger Finder
// by Nicholas Zambetti <http://www.zambetti.com>
// and James Tichenor <http://www.jamestichenor.net>
// Demonstrates use of the Wire library reading data from the
// Devantech Utrasonic Rangers SFR08 and SFR10
// Created 29 April 2006
// This example code is in the public domain.
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial communication at 9600bps
int reading = 0;
// step 1: instruct sensor to read echoes
Wire.beginTransmission(112); // transmit to device #112 (0x70)
// the address specified in the datasheet is 224 (0xE0)
// but i2c adressing uses the high 7 bits so it's 112
Wire.write(byte(0x00)); // sets register pointer to the command register (0x00)
Wire.write(byte(0x50)); // command sensor to measure in "inches" (0x50)
// use 0x51 for centimeters
// use 0x52 for ping microseconds
Wire.endTransmission(); // stop transmitting
// step 2: wait for readings to happen
delay(70); // datasheet suggests at least 65 milliseconds
// step 3: instruct sensor to return a particular echo reading
Wire.write(byte(0x02)); // sets register pointer to echo #1 register (0x02)
// step 4: request reading from sensor
Wire.requestFrom(112, 2); // request 2 bytes from slave device #112
// step 5: receive reading from sensor
if(2 <= Wire.available()) // if two bytes were received
reading = Wire.read(); // receive high byte (overwrites previous reading)
reading = reading << 8; // shift high byte to be high 8 bits
reading |= Wire.read(); // receive low byte as lower 8 bits
Serial.println(reading); // print the reading
delay(250); // wait a bit since people have to read the output :)
// The following code changes the address of a Devantech Ultrasonic Range Finder (SRF10 or SRF08)
// usage: changeAddress(0x70, 0xE6);
void changeAddress(byte oldAddress, byte newAddress)
Wire.beginTransmission(oldAddress);
Wire.write(byte(0xA0));
Wire.write(byte(0xAA));
Wire.write(byte(0xA5));
Wire.write(newAddress);
The code is designed to return an integer value, which it does perfectly fine. However I need a more accurate reading than an integer value- at least two decimal places. How can I change the code to return a float value?
I try changing the declaration for "reading" from
int reading = 0;
to float reading = 0.00;
but I get the following error:
SRF08.ino: In function 'void loop()':
SRF08:50: error: invalid operands of types 'float' and 'int' to binary 'operator<<'
SRF08:51: error: invalid operands of types 'float' and 'int' to binary 'operator|'
SRF08:51: error: in evaluation of 'operator|=(float, int)'
in step 5 of the code.
Thanks for any help!
