Using the tjctm24024-spi display
Hello,
I bought a 2.4" tjctm24024-spi display and I am having a little bit of trouble with it.
The TFT example from the Arduino does not work and when I try to compile the Adafruit libraries I get various errors. I don’t know why because I have not touched them.
I am using a 3.3V arduino pro mini 328 at the moment.
I found a demo code here:
http://www.elecfreaks.com/store/24-tft-lcd-tft0124sp-p-785.html
#include "pins_arduino.h"
#define LCD_CS		2
#define LCD_REST	3
#define LCD_DC		4
#define LCD_MOSI	5
#define LCD_CLK		6
volatile uint8_t *P_SCK,*P_MOSI,*P_DC,*P_RST,*P_CS;
volatile uint8_t B_SCK,B_MOSI,B_DC,B_RST,B_CS;
#define LCD_W	240
#define LCD_H	320
//color define
#define WHITE         	 0xFFFF
#define BLACK         	 0x0000
#define BLUE         	 0x001F
#define BRED             0XF81F
#define GRED 			 0XFFE0
#define GBLUE			 0X07FF
#define RED           	 0xF800
#define MAGENTA       	 0xF81F
#define GREEN         	 0x07E0
#define CYAN          	 0x7FFF
#define YELLOW        	 0xFFE0
#define BROWN 			 0XBC40
#define BRRED 			 0XFC07
#define GRAY  			 0X8430
void LCD_Write_Bus(char dat)
  *P_CS &= ~B_CS;
  for(uint8_t i=0;i<8;i++)
    if(dat&0x80)
      *P_MOSI |= B_MOSI;
      *P_MOSI &= ~B_MOSI;
    dat <<= 1;
    *P_SCK &= ~B_SCK;
    asm("nop");
    *P_SCK |= B_SCK;
  *P_CS |= B_CS;
void LCD_WR_DATA8(char dat)
	digitalWrite(LCD_DC,HIGH);
	LCD_Write_Bus(dat);
void LCD_WR_DATA(int dat)
	LCD_Write_Bus(dat>>8);
	LCD_Write_Bus(dat);
void LCD_WR_REG(char dat)
	digitalWrite(LCD_DC,LOW);
	LCD_Write_Bus(dat);
void LCD_WR_REG_DATA(int reg,int dat)
	LCD_WR_REG(reg);
	LCD_WR_DATA(dat);
void Address_set(unsigned int x1,unsigned y1,unsigned int x2,unsigned int y2)
	LCD_WR_REG(0x2a);
   	LCD_WR_DATA8(x1>>8);
   	LCD_WR_DATA8(x1);
   	LCD_WR_DATA8(x2>>8);
   	LCD_WR_DATA8(x2);
   	LCD_WR_REG(0x2b);
   	LCD_WR_DATA8(y1>>8);
   	LCD_WR_DATA8(y1);
   	LCD_WR_DATA8(y2>>8);
   	LCD_WR_DATA8(y2);
   	LCD_WR_REG(0x2C);
void LCD_Init(void)
        P_SCK	= portOutputRegister(digitalPinToPort(LCD_CLK));
        B_SCK	= digitalPinToBitMask(LCD_CLK);
	P_MOSI	= portOutputRegister(digitalPinToPort(LCD_MOSI));
	B_MOSI	= digitalPinToBitMask(LCD_MOSI);
	P_DC	= portOutputRegister(digitalPinToPort(LCD_DC));
	B_DC	= digitalPinToBitMask(LCD_DC);
	P_RST	= portOutputRegister(digitalPinToPort(LCD_REST));
	B_RST	= digitalPinToBitMask(LCD_REST);
	P_CS	= portOutputRegister(digitalPinToPort(LCD_CS));
	B_CS	= digitalPinToBitMask(LCD_CS);
        *P_RST &= ~B_RST;
	delay(20);
        *P_RST |= B_RST;
 	LCD_WR_REG(0xCB);
      LCD_WR_DATA8(0x39);
      LCD_WR_DATA8(0x2C);
      LCD_WR_DATA8(0x00);
      LCD_WR_DATA8(0x34);
      LCD_WR_DATA8(0x02);
      LCD_WR_REG(0xCF);
      LCD_WR_DATA8(0x00);
      LCD_WR_DATA8(0XC1);
      LCD_WR_DATA8(0X30);
  	LCD_WR_REG(0xE8);
      LCD_WR_DATA8(0x85);
      LCD_WR_DATA8(0x00);
      LCD_WR_DATA8(0x78);
  	LCD_WR_REG(0xEA);
      LCD_WR_DATA8(0x00);
      LCD_WR_DATA8(0x00);
  	LCD_WR_REG(0xED);
      LCD_WR_DATA8(0x64);
      LCD_WR_DATA8(0x03);
      LCD_WR_DATA8(0X12);
      LCD_WR_DATA8(0X81);
      LCD_WR_REG(0xF7);
      LCD_WR_DATA8(0x20);
      LCD_WR_REG(0xC0);    //Power control
      LCD_WR_DATA8(0x23);   //VRH[5:0]
      LCD_WR_REG(0xC1);    //Power control
      LCD_WR_DATA8(0x10);   //SAP[2:0];BT[3:0]
      LCD_WR_REG(0xC5);    //VCM control
      LCD_WR_DATA8(0x3e);
      LCD_WR_DATA8(0x28);
      LCD_WR_REG(0xC7);    //VCM control2
      LCD_WR_DATA8(0x86);  //--
      LCD_WR_REG(0x36);    // Memory Access Control
      LCD_WR_DATA8(0x48); //
      LCD_WR_REG(0x3A);
      LCD_WR_DATA8(0x55);
      LCD_WR_REG(0xB1);
      LCD_WR_DATA8(0x00);
      LCD_WR_DATA8(0x18);
    LCD_WR_REG(0xB6);    // Display Function Control
    LCD_WR_DATA8(0x08);
    LCD_WR_DATA8(0x82);
    LCD_WR_DATA8(0x27);
	LCD_WR_REG(0xF2);    // 3Gamma Function Disable
    LCD_WR_DATA8(0x00);
	LCD_WR_REG(0x26);    //Gamma curve selected
    LCD_WR_DATA8(0x01);
 	LCD_WR_REG(0xE0);    //Set Gamma
    LCD_WR_DATA8(0x0F);
    LCD_WR_DATA8(0x31);
    LCD_WR_DATA8(0x2B);
    LCD_WR_DATA8(0x0C);
    LCD_WR_DATA8(0x0E);
    LCD_WR_DATA8(0x08);
    LCD_WR_DATA8(0x4E);
    LCD_WR_DATA8(0xF1);
    LCD_WR_DATA8(0x37);
    LCD_WR_DATA8(0x07);
    LCD_WR_DATA8(0x10);
    LCD_WR_DATA8(0x03);
    LCD_WR_DATA8(0x0E);
    LCD_WR_DATA8(0x09);
    LCD_WR_DATA8(0x00);
    LCD_WR_REG(0XE1);    //Set Gamma
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x0E);
    LCD_WR_DATA8(0x14);
    LCD_WR_DATA8(0x03);
    LCD_WR_DATA8(0x11);
    LCD_WR_DATA8(0x07);
    LCD_WR_DATA8(0x31);
    LCD_WR_DATA8(0xC1);
    LCD_WR_DATA8(0x48);
    LCD_WR_DATA8(0x08);
    LCD_WR_DATA8(0x0F);
    LCD_WR_DATA8(0x0C);
    LCD_WR_DATA8(0x31);
    LCD_WR_DATA8(0x36);
    LCD_WR_DATA8(0x0F);
	LCD_WR_REG(0x2A);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0xEF);
    LCD_WR_REG(0x2B);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x01);
    LCD_WR_DATA8(0x3F);
    LCD_WR_REG(0x11);    //Exit Sleep
    delay(120);
    LCD_WR_REG(0x29);    //Display on
    LCD_WR_REG(0x2c);
void LCD_Clear(unsigned int color)
	unsigned int i,j;
	Address_set(0,0,LCD_W-1,LCD_H-1);
    for(i=0;i<LCD_W;i++)
    	for (j=0;j<LCD_H;j++)
        	LCD_WR_DATA(color);
  unsigned char p;
  for(p=0;p<14;p++)
    pinMode(p,OUTPUT);
  LCD_Init();
    LCD_Clear(RED);
  LCD_Clear(BLUE);
  LCD_Clear(GREEN);
It works great. I want to add text to it and I would like some advice on the things I have to do. In the end I would like to be able to write text of various size and color and use the SD card. The touch function would be a nice bonus.
I don’t understand what they mean on the page when they say "TFT01_2.4 SP is a 2.4 “SPI TFT LCD Screen Module, 10pins interface, compatible LCD5110 interface.” I used the 5110 display and managed to make it work with libraries and without libraries.
I assume that first I would have to do is add the ASCII characters. Something like this:
static const byte ASCII[][5] =
    0x7e, 0x11, 0x11, 0x11, 0x7e                            } // 41 A
    0x7f, 0x49, 0x49, 0x49, 0x36                            } // 42 B
    0x3e, 0x41, 0x41, 0x41, 0x22                            } // 43 C
