Using the tone() command with MIDI.
Hi all.
I just picked up a 2nd MIDI shield :slight_smile: The first shield is doing it’s job of lighting LEDs via note on/off on another project. The new shield is currently atop an UNO waiting for code. I haven’t come across an example or project for what I want to do, that will simply do note on/note off triggering the internal square wave. I assume that the tone() command in conjunction with pitches.h needs to be combined with the MIDI input commands. I messed around a bit hoping to somehow slipstream some code into the MIDI_IN (sketch below) I’m using to light the LEDs, but no luck.
So basically, these 2 codes. so that not only do I see the led light up per note but also hear a tone().
/* Midi In Basic  0.2 // kuki 8.2007
 * listen for midi serial data, and light leds for individual notes
 IMPORTANT:
 your arduino might not start if it receives data directly after a reset, because the bootloader thinks you want to uplad a new progam.
 you might need to unplug the midi-hardware until the board is running your program. that is when that statusLed turns on.
SOMETHING ABOUT MIDI MESSAGES
 midi messages start with one status byte followed by 1 _or_ 2 data bytes, depending on the command
 example midi message: 144-36-100
   the status byte "144" tells us what to do. "144" means "note on".
   in this case the second bytes tells us which note to play (36=middle C)
   the third byte is the velocity for that note (that is how powerful the note was struck= 100)
 example midi message: 128-36
   this message is a "note off" message (status byte = 128). it is followed by the note (data byte = 36)
   since "note off" messages don't need a velocity value (it's just OFF) there will be no third byte in this case
   NOTE: some midi keyboards will never send a "note off" message, but rather a "note on with zero velocity"
 do a web search for midi messages to learn more about aftertouch, poly-pressure, midi time code, midi clock and more interesting things.
HARDWARE NOTE:
The Midi Socket is connected to arduino RX through an opto-isolator to invert the midi signal and seperate the circuits of individual instruments.
connect 8 leds to pin2-pin9 on your arduino.
//variables setup
byte incomingByte;
byte note;
byte velocity;
int statusLed = 13;   // select the pin for the LED
int action=2; //0 =note off ; 1=note on ; 2= nada
//setup: declaring iputs and outputs and begin serial
  pinMode(statusLed,OUTPUT);   // declare the LED's pin as output
  pinMode(2,OUTPUT);
  pinMode(3,OUTPUT);
  pinMode(4,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(7,OUTPUT);
  pinMode(8,OUTPUT);
  pinMode(9,OUTPUT);
  //start serial with midi baudrate 31250 or 38400 for debugging
  Serial.begin(31250);
  digitalWrite(statusLed,HIGH);
//loop: wait for serial data, and interpret the message
void loop () {
  if (Serial.available() > 0) {
    // read the incoming byte:
    incomingByte = Serial.read();
    // wait for as status-byte, channel 1, note on or off
    if (incomingByte== 144){ // note on message starting starting
      action=1;
    }else if (incomingByte== 128){ // note off message starting
      action=0;
    }else if (incomingByte== 208){ // aftertouch message starting
       //not implemented yet
    }else if (incomingByte== 160){ // polypressure message starting
    }else if ( (action==0)&&(note==0) ){ // if we received a "note off", we wait for which note (databyte)
      note=incomingByte;
      playNote(note, 0);
      note=0;
      velocity=0;
      action=2;
    }else if ( (action==1)&&(note==0) ){ // if we received a "note on", we wait for the note (databyte)
      note=incomingByte;
    }else if ( (action==1)&&(note!=0) ){ // ...and then the velocity
      velocity=incomingByte;
      playNote(note, velocity);
      note=0;
      velocity=0;
      action=0;
    }else{
      //nada
void blink(){
  digitalWrite(statusLed, HIGH);
  delay(100);
  digitalWrite(statusLed, LOW);
  delay(100);
void playNote(byte note, byte velocity){
  int value=LOW;
  if (velocity >10){
      value=HIGH;
  }else{
   value=LOW;
 //since we don't want to "play" all notes we wait for a note between 36 & 44
 if(note>=36 && note<44){
   byte myPin=note-34; // to get a pinnumber between 2 and 9
   digitalWrite(myPin, value);
and
  Melody
 Plays a melody
 circuit:
 * 8-ohm speaker on digital pin 8
 created 21 Jan 2010
 modified 30 Aug 2011
 by Tom Igoe
This example code is in the public domain.
 http://arduino.cc/en/Tutorial/Tone
 #include "pitches.h"
// notes in the melody:
int melody[] = {
  NOTE_C4, NOTE_G3,NOTE_G3, NOTE_A3, NOTE_G3,0, NOTE_B3, NOTE_C4};
// note durations: 4 = quarter note, 8 = eighth note, etc.:
int noteDurations[] = {
  4, 8, 8, 4,4,4,4,4 };
  // iterate over the notes of the melody:
  for (int thisNote = 0; thisNote < 8; thisNote++) {
    // to calculate the note duration, take one second
    // divided by the note type.
    //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
    int noteDuration = 1000/noteDurations[thisNote];
    tone(8, melody[thisNote],noteDuration);
    // to distinguish the notes, set a minimum time between them.
    // the note's duration + 30% seems to work well:
    int pauseBetweenNotes = noteDuration * 1.30;
    delay(pauseBetweenNotes);
    // stop the tone playing:
    noTone(8);
  // no need to repeat the melody.
Honestly, I don’t care about the LEDs this time as much as being able to play notes off the Arduino via MIDI. I’m just thinking the concept is the same but sound instead of light.
If anyone out has messed around with something like this or can help, much appreciated.
Thanks in advance!
Rob
So you want to light the LED corresponding to the current note?
If so, add code to turn the LED on after tone(), and to turn it off after noTone(). I'd put all that into your playNote() subroutine.
BTW an 8 Ohm speaker connected immediately to an output pin can easily roast your Arduino :-(
DrDiettrich: So you want to light the LED corresponding to the current note?
Thanks for the reply. Sorry for any confusion. No LEDS this time. I was just stating what my project was with the first MIDI shield. I shouldn't have really even mentioned it.
All I want to do is: trigger the internal square wave via MIDI. I don't need a speaker as an output, just a low level line out that I will plug into an amplifier.
