using the vernier sensor interface shield
I was receiving some error messages with my code that I wasn't sure how to fix. Here is the code that I used.The error message was 'ThermistorPin' was not declared in this scope.
VernierThermistor (v 2013.11)
Reads the temperature from a Vernier Stainless Steel Temperature Probe (TMP-BTA)
or Surface Temperature Sensor (STS-BTA) connected to the BTA connector.
As written, the readings will be displayed every half second. Change the variable
TimeBetweenReadings to change the rate.
We use the Steinhart-Hart equation (in the function Thermistor) to determine temperature
from the raw A/D converter reading. Because of the use of log functions, in the Steinhart-Hart
equation, this sketch requires the math.h library.
See www.vernier.com/engineering/stem/sensors/temperature-sensor/
for more information on how thermistors are read.
Modifications by B. Huang (Feb 2014)
Removed the use of delays in the loop() function. Uses a timeRef variable
Added a variable called dataRate. dataRate describes the # of samples per second.
Added separate functions for calculating the resistance of the thermistor and then applying the
Steinhart-hart equation.
See www.vernier.com/arduino for more information.
float dataRate = 2;             // set # of samples per second.
const char delimiter = '\t';  // delimitter character
const int ThermistorPIN = A0; // A0 for Analog1 and A2 for Analog 2
float Temp;
int rawAnalogReading;
// Variables used in the code for calculations
unsigned long timeRef;    // reference for starting time
unsigned long timeInterval;
unsigned long ndx;        // index for data counter
unsigned long thermistor;
 Serial.println("Vernier Format 2");
 Serial.println("Temperature Readings taken using Ardunio");
 Serial.println("Data Set");
 Serial.print("Time");
 Serial.print("\t"); //tab character
 Serial.println ("Temperature");
 Serial.print("seconds");
 Serial.print("\t"); // tab character
 Serial.println ("degrees C");
 timeInterval = 1000 / dataRate;  // calculates the timeInterval based on # of samples per second.
 timeRef = millis();
 if ((millis()) >= ndx*timeInterval + timeRef)  // controls so only runs once per timeInterval
   ndx++;
   //the print below does the division first to avoid overflows
   Serial.print((float)(millis() - timeRef) / 1000, 2);
   rawAnalogReading = analogRead(ThermistorPIN);  // reads raw analog value from Arduino
   thermistor = resistance(rawAnalogReading);     // converts raw analog value to a resistance
   Temp = steinharthart(thermistor);              // Applies the Steinhart-hart equation
   Serial.print(delimiter); //tab character
   Serial.println(Temp,1);   // display temperature to one digit
unsigned long resistance(unsigned long rawAnalogInput)
/* function to convert the raw Analog Input reading to a resistance value
* Schematic:
*   [Ground] -- [thermistor] -------- | -- [15,000 ohm bridge resistor] --[Vcc (5v)]
*                                Analog Pin 0
* For the circuit above:
* Resistance = ((rawAnalogInput*15000) /(1023 - rawAnalogInput))
 unsigned long temp;  // temporary variable to store calculations in
 temp = (rawAnalogInput * 15000) / (1023 - rawAnalogInput);
 return temp; // returns the value calculated to the calling function.
float steinharthart(unsigned long resistance)
// function users steinhart-hart equation to return a temperature in degrees celsius.
/* Inputs ADC count from Thermistor and outputs Temperature in Celsius
* There is a huge amount of information on the web about using thermistors with the Arduino.
* Here we are concerned about using the Vernier Stainless Steel Temperature Probe TMP-BTA and the
* Vernier Surface Temperature Probe STS-BTA, but the general principles are easy to extend to other
* thermistors.
* This version utilizes the Steinhart-Hart Thermistor Equation:
*    Temperature in Kelvin = 1 / {A + B[ln(R)] + C[ln(R)]^3}
*   for the themistor in the Vernier TMP-BTA probe:
*    A =0.00102119 , B = 0.000222468 and C = 1.33342E-7
*    Using these values should get agreement within 1 degree C to the same probe used with one
*    of the Vernier interfaces
 float temp; // temporary variable to store calculations in
 float logRes = log(resistance);
 // calculating logirithms is time consuming for a microcontroller - so we just
 // do this once and store it to a variable.
 float k0 = 0.00102119;
 float k1 = 0.000222468;
 float k2 = 0.000000133342;
 temp = 1 / (k0 + k1 * logRes + k2 * logRes*logRes*logRes);
 temp = temp - 273.15;  // convert from Kelvin to Celsius
 return temp;
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
