I have a problem: I am trying to play a set of sounds in a loop, and using the Wire.h library causes my system to skip the first two(2) instances. after the first two , all is well again. (no actual use of Wire.h was made yet, just including the library at the begining).
if I don't use the Wire.h , it works fine (but I want it as I am to add an LCD display).
I am using the TMRpcm library for playing the sounds.
any help on this will be very appreciated ...
Thanks!
#include <Wire.h>
#include <TMRpcm.h>
#include <SD.h>
//#include <Adafruit_BMP085.h>
TMRpcm tmrpcm;
//Adafruit_BMP085 bmp;
int ist;
int digipin1 = 6; // white
int stopping = 0;
String station = "";
String Nstation = "";
char stationchar[20];
char Nstationchar[20];
float alt = 0;
Serial.begin(38400);
pinMode(digipin1, INPUT); // sets the digital pin 6 as input (stopped=0 , moving=1)
tmrpcm.speakerPin = 9; //Set speaker output pin to 9
pinMode(9, INPUT);
if (!SD.begin(10)) {
Serial.println("SD card initialization failed!");
return;
//digitalWrite(9,HIGH);
//tmrpcm.volume(1);
// if (!bmp.begin()) {
// Serial.println("Could not find a valid BMP085 sensor, check wiring!");
// while (1) {}
ist = 0;
String Stationname(int ist)
String service;
switch(ist) {
case (1):
service = ("paris");
case (2):
service = ("solel");
case (3):
service = ("neviim");
case (4):
service = ("masada");
case (5):
service = ("golomb");
case (6):
service = ("ganhaem");
case (7):
case (8):
case (9):
case (10):
case (11):
return service;
stopping = digitalRead(digipin1);
if (stopping > 0.8) {
Serial.print("ist = ");
Serial.println(ist);
if (ist < 0.5)
ist = 1;
else if (ist > 10.5)
ist = 1;
station = ("A" + Stationname(ist) + ".wav");
station.toCharArray(stationchar,15);
tmrpcm.play(stationchar);
Serial.println(stationchar);
delay (10000);
else {
delay (10000);
while (stopping > 0.8){
if (stopping < 0.2) {
delay(10000);
ist = ist+1;
Nstation = ("C" + Stationname(ist) + ".wav");
Nstation.toCharArray(Nstationchar,15);
tmrpcm.play(Nstationchar);
Serial.println(Nstationchar);
delay(6000);
Serial.print(" stopping=");
Serial.println(stopping);
Serial.println("");
