Using this code, I get the following error
int LEDpin = 2;  // connect MIC pin 4 to Arduino pin 2
  pinMode(LEDpin, OUTPUT);  // Tells the arduino which pin is used
int Cycle = 0;
While (Cycle < 10)
  if (cycle < 9)
    digitalWrite(LEDpin, HIGH);    // Turn the LED on
    Serial.println("LED IS ON");   // display text to verify led is on
    delay(1000);                   // Wait for 1 second
    digitalWrite(LEDpin, LOW);     // Turn the LED off
    Serial.println("LED IS OFF");  // display text to verify led is off
    delay(500);                    // Wait for .5 second
    delay(2000);                 // Wait for 2 second
  cycle = cycle + 1;
***> Blockquote***
here is the error message
C:\Users\mbanks\Documents\Arduino\MOSFET_LED\MOSFET_LED.ino:9:7: error: expected constructor, destructor, or type conversion before '(' token
While (Cycle != 10) {
exit status 1
Compilation error: expected constructor, destructor, or type conversion before '(' token
Capitalisation counts 'while'.
while with lower case 'w'
with the lowercase while I get the following error message.
C:\Users\mbanks\Documents\Arduino\MOSFET_LED\MOSFET_LED.ino:10:1: error: expected unqualified-id before 'while'
while (Cycle < 10)
exit status 1
Compilation error: expected unqualified-id before 'while'
You're missing a loop() function. The whole block after the setup() function should be in a function (e.g. loop())
that was it thank you.
So you fixed Cycle vs. cycle too?
And added
to the setup() function?
a7, with help from chatGPT…
