Using three SHT20 sensors on Arduino Uno Wifi - SPI problem
H i,
i’m trying to use three SHT20 sensors in my project. I am using an Arduino Uno Wifi rev2.
The problem is that these sensors make use of the SPI pins. It has four cables:
red => 5v
black => gnd
yellow=>SCK
green=> SDA
I only have one SCK and SDA pin. I know that you cannot put three sensors on the same pin, but how to make this work…
Google is not helping me out. I did find a post where someone hinted on using a software SPI. I found a library but i’m not having the faintest idea how to use it.
Can anyone give me a clue on what to do?
The code for these sensors:
#include <Wire.h>
#include "DFRobot_SHT20.h"
DFRobot_SHT20    sht20;
    Serial.println("SHT20 Example!");
    sht20.initSHT20();                                  // Init SHT20 Sensor
    delay(100);
    sht20.checkSHT20();                                 // Check SHT20 Sensor
    float humd = sht20.readHumidity();                  // Read Humidity
    float temp = sht20.readTemperature();               // Read Temperature
    Serial.print("Time:");
    Serial.print(millis());
    Serial.print(" Temperature:");
    Serial.print(temp, 1);
    Serial.print("C");
    Serial.print(" Humidity:");
    Serial.print(humd, 1);
    Serial.print("%");
Many thanks for any assistance!!
Scoobie
dual 4-1 bidirectional mux. can be found as a singe chip . can this on be used? SN74CBT3257C check around.. there may be other chips for this task
This is exactly what i am looking for! Thank you for your help!!
