Argh, sorry, I'm realy feeling stupid in programming language
My first approach was to make the time with a potmeter for one relay.
Then I did the BWOD for the secound relay and combined those two.
That seemed to work as I expected.
#define potPin4 A3 // Time 1
#define potPin5 A4 // Time 2
#define pirPin1 2 // PIR 1 sensor
#define pirPin2 3 // PIR 2 sensor
#define relayPin1 9 // Blower 1 (Relay for AC 220V)
#define relayPin2 10 // Blower 2 (Relay for AC 220V)
#define relayPin3 11 // Valve 1 (Relay for DC 12V)
#define relayPin4 12 // Valve 2 (Relay for DC 12V)
//#define ledPin 13 // Test LED Onboard
int pirState1 = LOW;
int pirState2 = LOW;
int relayValue1 = 0;
int relayValue2 = 0;
int relayValue3 = 0;
int relayValue4 = 0;
int relayState1 = 0;
int relayState2 = 0;
int relayState3 = 0;
int relayState4 = 0;
int val = 0;
#define pirType1 'L' // PIR trigger type. L for low and H for high
#define pirType2 'L' // PIR trigger type. L for low and H for high
#define relayType1 'L' // Relay trigger type. L for low and H for high
#define relayType2 'L' // Relay trigger type. L for low and H for high
#define relayType3 'L' // Relay trigger type. L for low and H for high
#define relayType4 'L' // Relay trigger type. L for low and H for high
//--------- TIMER:
//because the time below is in millisecond, 1000ms=1 second, 1000x60=60000 is 1 minuets. 60x60x1000=3600000 is 1 hour
const long maxTime = 30000;// maximum timer time in milliseconds. for one minute =60000, 1 hours =3600000
const long minTime = 3000; // miniimum timer time in milliseconds
long duration1;
long duration2;
long duration3;
long duration4;
int potValue4;
int potValue5;
long rememTime1;
long rememTime2;
long rememTime3;
long rememTime4;
//--------- BWOD:
// Variables will change:
//int relayState1 = LOW; // ledState used to set the LED
unsigned long previousMillis1 = 0; // will store last time LED was updated
//int relayState2 = LOW; // ledState used to set the LED
unsigned long previousMillis2 = 0; // will store last time LED was updated
//int relayState3 = LOW; // ledState used to set the LED
unsigned long previousMillis3 = 0; // will store last time LED was updated
//int relayState4 = LOW; // ledState used to set the LED
unsigned long previousMillis4 = 0; // will store last time LED was updated
// for the pulse led....
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
unsigned long interval1; // interval at which to blink (milliseconds)
unsigned long onTime1 = 100;
unsigned long offTime1 = 100;
unsigned long interval2; // interval at which to blink (milliseconds)
unsigned long onTime2 = 100;
unsigned long offTime2 = 100;
unsigned long interval3; // interval at which to blink (milliseconds)
unsigned long onTime3 = 100;
unsigned long offTime3 = 100;
unsigned long interval4; // interval at which to blink (milliseconds)
unsigned long onTime4 = 100;
unsigned long offTime4 = 100;
Serial.begin(9600);// initialize serial monitor with 9600 baud
pinMode(pirPin1, INPUT); // PIR Input
pinMode(pirPin2, INPUT); // PIR Input
pinMode(relayPin1, OUTPUT); //Relay for BLOWER 1
pinMode(relayPin2, OUTPUT); //Relay for VALVE 1
pinMode(relayPin3, OUTPUT); //Relay for BLOWER 2
pinMode(relayPin4, OUTPUT); //Relay for VALVE 2
if (pirType1 == 'L')
digitalWrite(relayPin1, LOW);// turn the OFF and keep it OFF
//Serial.println("MOTOR 1 Timer");
//Serial.println("Motor 1 Type: LOW Trigger");
digitalWrite(relayPin1, HIGH);// turn the relay OFF and keep it OFF
//Serial.println("Motor 1 Type: HIGH Trigger");
if (pirType2 == 'L')
digitalWrite(relayPin2, LOW);// turn the OFF and keep it OFF
// Serial.println("MOTOR 1 Timer");
// Serial.println("Motor 1 Type: LOW Trigger");
digitalWrite(relayPin2, HIGH);// turn the relay OFF and keep it OFF
// Serial.println("Motor 1 Type: HIGH Trigger");
if (relayType1 == 'L')
digitalWrite(relayPin1, LOW);// turn the relay OFF and keep it OFF
if (relayType2 == 'L')
digitalWrite(relayPin2, LOW);// turn the relay OFF and keep it OFF
if (relayType3 == 'L')
digitalWrite(relayPin3, HIGH);// turn the relay OFF and keep it OFF
digitalWrite(relayPin3, LOW);// turn the relay OFF and keep it OFF
if (relayType4 == 'L')
digitalWrite(relayPin4, LOW);// turn the relay OFF and keep it OFF
digitalWrite(relayPin4, HIGH);// turn the relay OFF and keep it OFF
// here is where you'd put code that needs to be running all the time.
pulseRelay1(); //bwod
// pulseRelay2(); //bwod
//######## TIMER 1 Blower 1 and Valve 1 #########
potValue4 = analogRead(potPin4) / 2; // reads the value of the potentiometer (value between 0 and 1023)
duration1 = map(potValue4, 0, 102, minTime, maxTime);// convert A0 value to time set at minTime and maxTime
if (digitalRead(pirPin1) == HIGH)
rememTime1 = millis();
relayState1 = 1;
controlRelay1();// send command to turn the relay ON
if ( (millis() - rememTime1) > duration1 )
relayState1 = 0;
controlRelay1();
Serial.print("Time Relay 1 : ");
Serial.print(duration1 / 1000);
Serial.println(" Seconds");
delay(200); // wait for 200 milliseconds
//######## CONTROL Blower 1 and Valve 1 #########
void controlRelay1() {
if (relayState1 == 1)
digitalWrite(relayPin1, LOW); // turn OFF RELAY Blower 1
digitalWrite(relayPin3, HIGH); // turn OFF RELAY Valve 1
//Serial.println("Relay and valve 1 is ON");
digitalWrite(relayPin1, HIGH);// Turn ON RELAY Blower 1
digitalWrite(relayPin3, LOW);// Turn ON RELAY Valve 1
//Serial.println("====RELAY 1 and valve 1 is OFF");
void pulseRelay1()
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
//Serial.println("in pulseLED");
unsigned long currentMillis = millis();
if (currentMillis - previousMillis1 > interval1) {
// save the last time you blinked the LED
previousMillis1 = currentMillis;
// if the LED is off turn it on and vice-versa:
if (relayState1 == HIGH)
relayState1 = LOW;
// set the interval to how long it must stay on
interval1 = onTime1;
relayState1 = HIGH;
// set the interval to how long it must stay off
interval1 = offTime1;
// set the LED with the ledState of the variable:
digitalWrite(relayPin3, relayState1);
Then I tried to add the code for two more relays. That is were I'm getting lost and I think I must have overlooked or missing something.
If you can see what I'm doing wrong, can you please give a hint?
Maybe like an code example from my sketch.
I will really appreciate that an again sorre for my lack of skills
