Hi I want to use timerone with lcd normally lcd working but if ı decrease OCR1A=159; lcd not working
thanks
#include <Wire.h>
#include <EEPROM.h>
#include <TimerOne.h>
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // See above - same as DF Robot
char* menu[] = {
"Ali", "veli", "a3", "a4", "a5", "a6",
"a7", "a8", "a9", "a10", "a11", "a12",
"a13", "A14", "A15", "A16", "A17", "A18", "A19",
"a20", "a21"
int freqvar[21] = {
6947, 4900, 8000, 8830, 1414, 11646, 11902, 12692, 16760, 17032, 700, 4000, 4139, 4500, 5400, 5480, 1600, 5200, 5301, 5373, 5494
int dutyvar[21];
int freq[21];
int freq_addr[] = {
50, 52, 54, 56, 58, 60, 62, 64, 66, 68, 70, 72, 74, 76, 78, 80, 82, 84, 86, 88, 90, 92, 94
byte menum;
float duty_on;
float duty_off;
int buttonState[6];
int duty[21] = {
70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90
int duty_addr[] = {
100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120
int i;
int y;
int x;
int buttonPin[] = {
2, 3, 4, 5, 6, 7};
float pil_sev;
float pulseWidth;
int pulseWidthScaled;
int PWCurrent;
byte PWTolerance = 8;
int frequency;
int freqCurrent;
byte freqTolerance = 2;
unsigned int freqScaled;
byte wave;
long t;
long samplerate;
long period;
lcd.begin (16, 2);
lcd.setBacklight(HIGH);
DDRD = DDRD | B11111100;
pinMode(9, OUTPUT);
cli();
TCCR1A=0;
TCCR1B=0;
OCR1A=159;
TCCR1B|=(1<<WGM12);
TCCR1B|=(1<<CS10);
TIMSK1|=(1<<OCIE1A);
samplerate = 100000;
Timer1.attachInterrupt(sinyal);
sei();
check_buttonState();
check_menu();
check_freq();
check_duty();
sinyal();
var();
pil();
void check_menu()
if (buttonState[0] == HIGH)
menum++;
if (menum == 21)
menum = 0;
delay(100);
buttonState[0] = LOW;
lcd.clear();
delay(50);
for (i = 0; i < 21; i++)
freq[i] = EEPROMReadlong(freq_addr[i]);
duty[i] = EEPROM.read(duty_addr[i]);
lcd.setCursor(0, 0);
lcd.print(menu[menum]);
void check_freq()
if (buttonState[1] == HIGH)
freq[menum]++;
delay(100);
if (buttonState[2] == HIGH)
freq[menum]--;
delay(100);
EEPROMWritelong(freq_addr[menum], freq[menum]);
freq[menum] = EEPROMReadlong(freq_addr[menum]);
frequency = freq[menum];
period = samplerate / frequency;
Serial.println(period);
Serial.println(frequency);
lcd.setCursor(0, 1);
lcd.print(freq[menum]);
void check_duty()
if (buttonState[3] == HIGH)
duty[menum]++;
delay(100);
if (buttonState[4] == HIGH)
duty[menum]--;
delay(100);
EEPROM.write(duty_addr[menum], duty[menum]);
if (duty[menum] > 100) {
EEPROM.write(duty_addr[menum], 0);
if (duty[menum] < 0) {
EEPROM.write(duty_addr[menum], 100);
duty[menum] = EEPROM.read(duty_addr[menum]);
pulseWidth = (duty[menum]);
pulseWidthScaled = pulseWidth * period / 100;
Serial.println(pulseWidthScaled);
Serial.println(duty[menum]);
Serial.println(pulseWidth);
lcd.setCursor(12, 0);
lcd.print("%");
lcd.setCursor(13, 0);
lcd.print(duty[menum]);
void sinyal()
t += 1;
if (t >= period) {
t = 0;
if (pulseWidthScaled <= t) {
digitalWrite(9, HIGH);
else {
digitalWrite(9, LOW);
void var()
if (buttonState[5] == HIGH)
for (i = 0; i < 22; i++)
EEPROMWritelong(freq_addr[i], freqvar[i]);
EEPROMWritelong(duty_addr[i], dutyvar[i]);
lcd.clear();
lcd.print("Kaydedildi");
menum = 0;
void pil()
pil_sev = analogRead(A3) * 9 / 1024;
lcd.setCursor(12, 1);
lcd.print(pil_sev);
void check_buttonState()
for (i = 0; i < 6; i++)
buttonState[i] = digitalRead(buttonPin[i]);
void EEPROMWritelong(int address, long value)
//Decomposition from a long to 4 bytes by using bitshift.
//One = Most significant -> Four = Least significant byte
byte one = (value & 0xFF);
byte two = ((value >> 8) & 0xFF);
//Write the 4 bytes into the eeprom memory.
EEPROM.write(address, two);
EEPROM.write(address + 1, one);
long EEPROMReadlong(long address)
//Read the 4 bytes from the eeprom memory.
long two = EEPROM.read(address + 1);
long one = EEPROM.read(address);
//Return the recomposed long by using bitshift.
return ((two << 0) & 0xFF) + ((one << 8) & 0xFFFF);
forum.ino (4.6 KB)
