Using timezonedb API to call time.
Hello,
I would like to develop a clock which gets the time from timezonedb using their API.
The plan is to display the time in the Serial Monitor.
I am using a adafruit eps32, with arduino IDE.
So far I have managed to connect to the Wifi, and check signal strength. All this is working correctly at the moment.
The problem I am having is I have never used API's and this is something I would like to learn more about and use in projects.
I would really appreciate some advice/help with how to implement the timezonedb API to get the time.
https://timezonedb.com/api
Thank you! :)
#include <WiFi.h>
#include <SPI.h>
#include <time.h>
const char* ssid = "NETWORK";
const char* password =  "PASSWORD";
int status = WL_IDLE_STATUS;
pinMode(LED_BUILTIN, OUTPUT);
  Serial.print("Connecting to WiFi network: ");
  Serial.println(ssid);
    status = WiFi.begin(ssid, password);
  Serial.print("Connected to WiFi network: ");
  Serial.print("Your IP: ");
void loop() {                                                        // the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH);                        // turn the LED on (HIGH is the voltage level)
delay(100);                                                       // wait for 0.1 second
digitalWrite(LED_BUILTIN, LOW);                       // turn the LED off by making the voltage LOW
delay(1000);                                                // wait for 0.1 second
// Checks network status
  if (WiFi.status() == WL_CONNECTED) {               // Checks network status
      Serial.print("WiFi Status: ");
      Serial.print("Connected to ");
    //WL_NO_SHIELD        = 255
    //WL_IDLE_STATUS      = 0
    //WL_NO_SSID_AVAIL    = 1
    //WL_SCAN_COMPLETED   = 2
    //WL_CONNECTED        = 3
    //WL_CONNECT_FAILED   = 4
    //WL_CONNECTION_LOST  = 5
    //WL_DISCONNECTED     = 6
//WiFi Singal Strength
long rssi = WiFi.RSSI();
unsigned long before = micros();
unsigned long after = micros();
Serial.print("Signal strength: ");
Serial.print(rssi);
Serial.println("dBm");
Serial.print("Took: ");
Serial.print(after - before);
Serial.println(" micro/seconds");
} // The End
