Using Tinysine Motorair wifi board
Have a problem loading onto board.
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
Using board 'pro' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539\sketch\motorair.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539\sketch\motorair.ino.cpp" -o "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539\preproc\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539\sketch\motorair.ino.cpp" -o "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539\sketch\motorair.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_cache_311693\core\core_arduino_avr_pro_cpu_16MHzatmega328_d72cf7820821928d7aba3a85f82dacbf.a
Linking everything together...
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539/motorair.ino.elf" "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539\sketch\motorair.ino.cpp.o" "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539/..\arduino_cache_311693\core\core_arduino_avr_pro_cpu_16MHzatmega328_d72cf7820821928d7aba3a85f82dacbf.a" "-LC:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539" -lm
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539/motorair.ino.elf" "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539/motorair.ino.eep"
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539/motorair.ino.elf" "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539/motorair.ino.hex"
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-size" -A "C:\Users\GRAFTO~1\AppData\Local\Temp\arduino_build_194539/motorair.ino.elf"
Sketch uses 2318 bytes (7%) of program storage space. Maximum is 30720 bytes.
Global variables use 191 bytes (9%) of dynamic memory, leaving 1857 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xcb
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xcb
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xcb
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xcb
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xcb
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xcb
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xcb
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xcb
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xcb
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xcb
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
