Hello,
I have a commercial project I am working on which makes use of many TLC59108 8-Channel PWM Controllers for LED animation. I have been using the Arduino compatibleTLC59108 library written by Christopher Smith 8 years ago found on Github here:
https://github.com/chrylis/tlc59108
This has been working great on the AVR based microcontrollers I've been using to test my boards. However I would now like to transitoin to using the new RP2040, and cannot get the library to work (code won't compile).
I'm not a C++ expert so I don't understand exactly whats going wrong. The library is short and I've read through it and can't see it doing anything that the new Arduino core for RP2040 wouldn't support. However, this is the first time using an ARM based controller rather than AVR, and I'm thinking maybe the compiler is a bit more strict in how libraries are written?
Here is an example sketch which reproduces the error:
#include <Wire.h>
#include "TLC59108.h"
#define HW_RESET_PIN 2
#define I2C_ADDR TLC59108::I2C_ADDR::BASE
TLC59108 leds(I2C_ADDR);
Wire.begin();
leds.init(HW_RESET_PIN);
leds.setLedOutputMode(TLC59108::LED_MODE::PWM_IND);
void loop(){
// Blink On
for(byte channel = 0; channel < 8; channel++)
leds.setBrightness(channel, 255);
// Blink off
leds.setBrightness(channel, 0);
This results in errors at compilation:
In file included from C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/platform/include/platform/platform.h:26:0,
from C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/platform/include/platform/FileHandle.h:25,
from C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/macros.h:28,
from C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\variants\RASPBERRY_PI_PICO/pins_arduino.h:2,
from C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/Arduino.h:79,
from C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\sweep.ino.cpp:1:
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/platform/include/platform/mbed_retarget.h:242:25: error: expected unqualified-id before numeric constant
#define EINVAL 22 /* Invalid argument */
C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.h:182:24: note: in expansion of macro 'EINVAL'
static const uint8_t EINVAL = 2;
from C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.h:23,
from C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.cpp:25:
C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.cpp: In static member function 'static void TLC59108::setDefaultI2C(TwoWire)':
C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.cpp:29:28: error: use of deleted function 'arduino::MbedI2C& arduino::MbedI2C::operator=(const arduino::MbedI2C&)'
TLC59108::i2c_default = i2c_default;
In file included from C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.h:24:0,
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\libraries\Wire/Wire.h:34:7: note: 'arduino::MbedI2C& arduino::MbedI2C::operator=(const arduino::MbedI2C&)' is implicitly deleted because the default definition would be ill-formed:
class MbedI2C : public HardwareI2C
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\libraries\Wire/Wire.h:34:7: error: use of deleted function 'rtos::Thread& rtos::Thread::operator=(const rtos::Thread&)'
In file included from C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/rtos.h:29:0,
from C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\libraries\Wire/Wire.h:28,
from C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.h:24,
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Thread.h:92:7: note: 'rtos::Thread& rtos::Thread::operator=(const rtos::Thread&)' is implicitly deleted because the default definition would be ill-formed:
class Thread : private mbed::NonCopyable<Thread> {
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Thread.h:92:7: error: use of deleted function 'mbed::NonCopyable<T>& mbed::NonCopyable<T>::operator=(const mbed::NonCopyable<T>&) [with T = rtos::Thread]'
In file included from C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/platform/include/platform/FileHandle.h:26:0,
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/platform/include/platform/NonCopyable.h:185:18: note: declared here
NonCopyable &operator=(const NonCopyable &) = delete;
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Thread.h:92:7: error: use of deleted function 'rtos::Semaphore& rtos::Semaphore::operator=(const rtos::Semaphore&)'
In file included from C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Thread.h:33:0,
from C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/rtos.h:29,
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Semaphore.h:50:7: note: 'rtos::Semaphore& rtos::Semaphore::operator=(const rtos::Semaphore&)' is implicitly deleted because the default definition would be ill-formed:
class Semaphore : private mbed::NonCopyable<Semaphore> {
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Semaphore.h:50:7: error: use of deleted function 'mbed::NonCopyable<T>& mbed::NonCopyable<T>::operator=(const mbed::NonCopyable<T>&) [with T = rtos::Semaphore]'
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Thread.h:92:7: error: use of deleted function 'rtos::Mutex& rtos::Mutex::operator=(const rtos::Mutex&)'
In file included from C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/platform/include/platform/PlatformMutex.h:42:0,
from C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/drivers/include/drivers/I2C.h:27,
from C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\libraries\Wire/Wire.h:24,
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Mutex.h:70:7: note: 'rtos::Mutex& rtos::Mutex::operator=(const rtos::Mutex&)' is implicitly deleted because the default definition would be ill-formed:
class Mutex : private mbed::NonCopyable<Mutex> {
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Mutex.h:70:7: error: use of deleted function 'mbed::NonCopyable<T>& mbed::NonCopyable<T>::operator=(const mbed::NonCopyable<T>&) [with T = rtos::Mutex]'
C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.cpp: In constructor 'TLC59108::TLC59108(TwoWire, byte)':
C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.cpp:32:84: error: use of deleted function 'arduino::MbedI2C::MbedI2C(const arduino::MbedI2C&)'
TLC59108::TLC59108(TwoWire i2c, const byte i2c_address): i2c(i2c), addr(i2c_address)
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\libraries\Wire/Wire.h:34:7: note: 'arduino::MbedI2C::MbedI2C(const arduino::MbedI2C&)' is implicitly deleted because the default definition would be ill-formed:
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\libraries\Wire/Wire.h:34:7: error: use of deleted function 'rtos::Thread::Thread(const rtos::Thread&)'
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Thread.h:92:7: note: 'rtos::Thread::Thread(const rtos::Thread&)' is implicitly deleted because the default definition would be ill-formed:
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Thread.h:92:7: error: use of deleted function 'mbed::NonCopyable<T>::NonCopyable(const mbed::NonCopyable<T>&) [with T = rtos::Thread]'
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/platform/include/platform/NonCopyable.h:179:5: note: declared here
NonCopyable(const NonCopyable &) = delete;
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Thread.h:92:7: error: use of deleted function 'rtos::Semaphore::Semaphore(const rtos::Semaphore&)'
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Semaphore.h:50:7: note: 'rtos::Semaphore::Semaphore(const rtos::Semaphore&)' is implicitly deleted because the default definition would be ill-formed:
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Semaphore.h:50:7: error: use of deleted function 'mbed::NonCopyable<T>::NonCopyable(const mbed::NonCopyable<T>&) [with T = rtos::Semaphore]'
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Thread.h:92:7: error: use of deleted function 'rtos::Mutex::Mutex(const rtos::Mutex&)'
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Mutex.h:70:7: note: 'rtos::Mutex::Mutex(const rtos::Mutex&)' is implicitly deleted because the default definition would be ill-formed:
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/rtos/include/rtos/Mutex.h:70:7: error: use of deleted function 'mbed::NonCopyable<T>::NonCopyable(const mbed::NonCopyable<T>&) [with T = rtos::Mutex]'
C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.cpp: In constructor 'TLC59108::TLC59108(byte)':
C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.cpp:36:61: error: no matching function for call to 'arduino::MbedI2C::MbedI2C()'
TLC59108::TLC59108(const byte i2c_address): addr(i2c_address)
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\libraries\Wire/Wire.h:37:5: note: candidate: arduino::MbedI2C::MbedI2C(int, int)
MbedI2C(int sda, int scl);
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\libraries\Wire/Wire.h:37:5: note: candidate expects 2 arguments, 0 provided
C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.cpp:38:10: error: use of deleted function 'arduino::MbedI2C& arduino::MbedI2C::operator=(const arduino::MbedI2C&)'
i2c = Wire;
C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.cpp: In member function 'uint8_t TLC59108::setBrightness(uint8_t, uint8_t)':
C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.cpp:111:20: note: in expansion of macro 'EINVAL'
return ERROR::EINVAL;
C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\cores\arduino/mbed/platform/include/platform/mbed_retarget.h:242:25: error: expected ';' before numeric constant
C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.cpp: In member function 'uint8_t TLC59108::setLedOutputMode(uint8_t)':
C:\Users\ALEXST~1\AppData\Local\Temp\arduino_build_252828\sketch\TLC59108.cpp:119:20: note: in expansion of macro 'EINVAL'
Using library Wire in folder: C:\Users\AlexStewart\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\2.0.0\libraries\Wire (legacy)
exit status 1
Error compiling for board Raspberry Pi Pico.
Any insight into what might be wrong would be greatly appreciated!
